Author Topic: Oil flush after rebuild and new turbo  (Read 4588 times)
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
« on: 01 April 2014, 13:51 »
It was suggested to me to do a run in service at 1000 miles, and to do oil flush but there are contradicting opinions on here?
What do you think?
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Re: Oil flush after rebuild and new turbo
« Reply #1 on: 01 April 2014, 13:54 »
I would avoid engine flush at all costs on a 1.8t for a lot of reasons.
Offline XMC1980
« Reply #2 on: 01 April 2014, 15:38 »
Wayne can you tell me your (a lot) of reasons? I'm sure you know your stuff but I want to research for myself aswell, you may be wrong or I might educate myself :wink:
Mk4 1.8T 218ps AUQ
« Reply #3 on: 02 April 2014, 12:08 »
The main reason is that engine flush tends to dislodge sediment that they can block oil feeds and pipes etc.
Offline Dalo Harkin
« Reply #4 on: 02 April 2014, 12:16 »
If you are adamant about using engine flush I would take the sump off and change the pick up pipe at the same time
Offline XMC1980
« Reply #5 on: 02 April 2014, 12:42 »
I'm caught between a rock and hard place with this one.... Hmmm
Mk4 1.8T 218ps AUQ
Offline XMC1980
« Reply #6 on: 02 April 2014, 12:55 »
I think a flush is really important and even necessary sometimes, but there are some who say that they would rather leave all the crap inside the engine preferring not to "dislodge" it from the side walls of the internal engine area.
Firstly, if any "sludge" fell off the inside walls of the engine it would fall into the sump, if somehow it would then manage to get sucked up into the engine oil the ways it would have to get trough to the really fine mesh that is on the bottom of the oil scavenge pick up filter (doubtful - if not impossible) but supposing it managed to get through the fine mesh on the pick up, it would then travel directly to the oil filter (that is what it is for) and there is NO WAY any crud can get through a paper centred oil filter, it isnt possible so lets not even go there.
So I dont listen to those that say "I would rather not in case it dislodged some crud on the inside of the engine".
The ONLY downside to having a engine flush is the cost and if you do it yourself then it's minimal to say the least.
Some say, They don't want their 1.8T  "flush" going through their turbo's, it may damage them.
This is a fair point, but not a good one, We all know that the turbo's dont spool up until the engine gets to about 1500 -2000 RPM, and I DO NOT rev the engine up when on a flush, I always let the enigne run for 30 to 40 minutes on TICKOVER, I do not reccomend that you drive the car or rev it above 1500rpm whilst flushing.
Mk4 1.8T 218ps AUQ
Offline XMC1980
« Reply #7 on: 02 April 2014, 12:58 »
Fresh oil and flush
pic host
« Last Edit: 02 April 2014, 13:03 by XMC1980 »
Mk4 1.8T 218ps AUQ
Offline XMC1980
« Reply #8 on: 02 April 2014, 13:01 »
After three flushes 70/30 ratio of gear oil and diesel
screen shot on pc
Mk4 1.8T 218ps AUQ
Offline XMC1980
« Reply #9 on: 02 April 2014, 16:33 »
What's your thoughts now?
Mk4 1.8T 218ps AUQ
