Author Topic: Removing gear linkage clips  (Read 1245 times)
Offline jamiesgolf
« on: 01 April 2014, 10:45 »
Hi, can't work out how you get these clips off as I don't want to force anything. I have a 2.0l gti 8v. Mine look like these http://www.ebay.ie/sch/Gear-Linkages-/174104/i.html.
Thanks for any help!
Offline dom
  • Back in a Mk4
Re: Removing gear linkage clips
« Reply #1 on: 01 April 2014, 11:29 »
Your link doesn't work, do you mean the clips with the springs the three prongs?
Offline jamiesgolf
« Reply #2 on: 01 April 2014, 11:59 »
I think so yeah, same as these ones http://forums.vwvortex.com/showthread.php?5432210-Need-Shift-Linkage-Help-2003-MK4-Golf-2.0
(Hope that link works)
Cheers for your help
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #3 on: 01 April 2014, 12:53 »
Easy enough gust pry the clip out (carefully!) with a small flat screwdrive and it will un-clip make sure to keep hold as these can be lost easily
2000 Mkiv GTi 1.8T AGU
Offline jamiesgolf
« Reply #4 on: 01 April 2014, 13:29 »
Okay cheers, where is the clip? Is it around the white disc bit?
Offline dom
  • Back in a Mk4
« Reply #5 on: 01 April 2014, 19:52 »
There are two different types of clip I think, a picture of yours would be useful.
Offline jamiesgolf
« Reply #6 on: 01 April 2014, 22:19 »
Hi, yeah I've got them off now. It was the type where you just pull it off, there was no clip. Thanks for your help anyway
