Author Topic: just noticed a leak need some opinions please  (Read 2993 times)
Offline Nino
« on: 01 April 2014, 07:24 »
Hey guys i just noticed a few palm sized spots on the floor about 50cm apart that have clearly come from my car as i parked up in work. It seems that it is defo on the drivers side of the car and it is blue is colour.  (after reacting with the water)
I quickly checked the oil which seemed fine and the coolent was above minimum so thats fine. Couldn't see anything wet under the bonnet god im gunna worry all day now. :(
« Last Edit: 01 April 2014, 08:05 by Nino »
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Dalo Harkin
Re: just noticed a leak need some opinions please
« Reply #1 on: 01 April 2014, 08:23 »
Do you have the underneath splash tray thing on?
Its hard to pinpoint leaks if you do have it on because chances are wherever it is coming from is hitting something on the way down and running off something.
You need to get underneath and follow the trail backwards to the source
Also remember that if it is oil a palm size amount after reacting with water could literally be a drop of actual oil.
Offline Nino
« Reply #2 on: 01 April 2014, 09:16 »
Good point there is no guard thou im gunna check levels of coolent, oil and brake fluid before i leave work and take it easy going home then ill jack her up and take a look i hope it isnt so
something expensive
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
« Reply #3 on: 01 April 2014, 10:38 »
Jack it up and get under it with a torch, spray brake and clutch cleaner on any staines areas and then check 24hrs later :smiley:
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline Nino
« Reply #4 on: 01 April 2014, 16:15 »
This is strange checked the car after work nothing and the patches that were there this morning are gone. And drove home and nothing. Im going to put some cardboard under the car overnight
Offline XMC1980
« Reply #5 on: 01 April 2014, 17:07 »
Too many disco biscuits in the heat of evolution :smiley:
Mk4 1.8T 218ps AUQ
Offline Nino
« Reply #6 on: 01 April 2014, 20:06 »
Huh?  :huh:
Offline Dalo Harkin
« Reply #7 on: 02 April 2014, 08:21 »
lol, I think he was implying you were on illegal substances at the time of looking under your car  :grin: :laugh: :grin:
Offline Nino
« Reply #8 on: 02 April 2014, 09:29 »
Ohhh no dont touch that stuff. However i removed the cardboard this morning and nothing was onit i think it was water that flipped up while driving and driping off something that might have had oil on there so all good :)
Offline XMC1980
« Reply #9 on: 02 April 2014, 10:01 »
Good work :cool:
Mk4 1.8T 218ps AUQ
