Author Topic: Anyone recognise this connector?  (Read 2365 times)
Offline Bazzer
« on: 02 September 2005, 12:17 »
Hi all. I've got a connector in the parcel shelf bit of the dash (Mk3) and I don't know what it is... I thought it may have been a Clifford thing but I've done some digging and they look a lot smaller than this one. It's about an inch wide.
Bazzer
Judderi
Re: Anyone recognise this connector?
« Reply #1 on: 02 September 2005, 12:19 »
Yes its the manual overide for the factory fitted conlog alarm. If you now have a clifford installed then its probably not needed anymore.
Offline Bazzer
« Reply #2 on: 02 September 2005, 12:29 »
Nuts. Anyone got a lower dash thing without a soddign great hole cut in it for me?!!  :laugh:
Bazzer
Judderi
« Reply #3 on: 02 September 2005, 12:34 »
The old fob looks like this. Notice the pins on the rear. This is the bit that you push in to turn the alarm off if the batteries in the fob die. Dunno why its been replaced as there very good alarms. Mine is anyway. Has anti hijack, panic, auto door closure the lot. Works a mile off and is loud as fcuk!
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 02 September 2005, 12:40 »
I might have the peice of dash you need. will have to ring my mum and ask her to have a look in the garage for it.
Mk4 Golf 150PD
Offline GTI EDITION (aka LTD)
« Reply #5 on: 02 September 2005, 13:26 »
Good alarms IMO easy to fit,  genuine connectors so potential Robin barsts can't easily work out which wiring is genuine factory and which is Conlog unlike some of the other after market alarms .
Mind you looks like they didn't even put it in straight  ( I know some of us that work/worked a VW dealerships do/did have pride in our work and fitted them properly  :wink: )
« Last Edit: 02 September 2005, 15:01 by Tarquin Fin-tin-lim-bin-lin-bim- bin-bim-bin bus-stop F'ttang F'ttang Olé Biscuit barrell ! »
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline Bazzer
« Reply #6 on: 02 September 2005, 14:27 »
Actually, after reading the last one it could have it's advantages if the socket stayed. Feefs might think there's a Conlog and a Clifford!  :laugh:
Bazzer
« Reply #7 on: 02 September 2005, 14:37 »
There you go ,  Keep the thevin little barsts guessing . If they have any doubt, they're more likely to leave it well alone   :grin: :grin:
Offline Bazzer
« Reply #8 on: 02 September 2005, 14:59 »
Just looked at the closeup pic... CHRIST I need to clean it properly!!  :grin:
Bazzer
