Author Topic: Stereo Woes  (Read 3953 times)
Offline Thom89
  • Looking for an "Icebreaker"
Re: Stereo Woes
« Reply #10 on: 22 April 2014, 00:01 »
Poor reception, and interference can be linked to the earth strap fitted to the N/S bonnet hinge being broken... worth a check
Thom
Offline DubUpYork
Re: Stereo Woes
« Reply #11 on: 22 April 2014, 18:52 »
Thanks Thom! I will check that when I get chance tomorrow after work...bit rainy at the moment :/
Offline robw09
Re: Stereo Woes
« Reply #12 on: 22 April 2014, 22:32 »
Thom
Thom, where is it exactly and is it easy to replace if broken?
Offline Thom89
Re: Stereo Woes
« Reply #13 on: 23 April 2014, 00:33 »
Thom
Open the bonnet, go to the N/S bonnet hinge... the hinge should have an earth strap where it bolts to the bonnet at one end, and bolted to the body at the other. The strap should be about 10 inches long, and have a black heat shrink cover over the braided part... Usually one end breaks away with old age, but can easily be fixed by opening up the terminal with a small flat blade screwdriver, and re crimping the braided copper wire. 10min job to mend, or 2 min job to replace
The strap is there to earth the bonnet to the body properly, this cuts down immensely on spurious interference signals emitted from the cars ignition system and interfering with the radio, especially if the car has a wing mounted aerial! Bee stings can still suffer, but to a lesser extent
HTH
Thom
« Last Edit: 23 April 2014, 00:59 by Thom89 »
Offline robw09
Re: Stereo Woes
« Reply #14 on: 23 April 2014, 12:06 »
Super.....shall take a look after this crappy conference call I am on :)
It is snapped on the wing side and the bonnet side is pretty perished....looks like it is a replacement part.  Could you give me a clue on where to get the part?
« Last Edit: 23 April 2014, 18:45 by robw09 »
Offline Sgt_Lemon
  • 8v owners club
Re: Stereo Woes
« Reply #15 on: 23 April 2014, 19:59 »
I found a perfect nick one in the scrappy, wasn't even looking for it but noticed one that looked virtually new.
Offline robw09
Re: Stereo Woes
« Reply #16 on: 23 April 2014, 20:11 »
Well i managed to salvage (butcher) the existing one and AM/LW is spot on now.  However, FM is still a bit dodgy, but it is pissing down and cloudy so.....
Offline Brighouse-gti
Re: Stereo Woes
« Reply #17 on: 23 April 2014, 20:26 »
Ariel on my mk2 used to pop up from the top of the passenger side wing, near to the scuttle. Other thing is that although it maybe smooth now, they might have once been a hole there!
