Author Topic: Bolt fitment !  (Read 2103 times)
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
Bolt fitment !
« on: 30 March 2014, 15:59 »
Bought some new alloys this weekend and im going to be fitting them Hopefully tomorrow if I have the right bolts!
the wheels are a8/rs8 reps,
The bolt goes in and sits flush it looks and feels right But i want abit of peace of mind before going ahead.
It is the correct size bolt, but its the shape im unsure about radius/tapered
Offline dom
  • Back in a Mk4
Re: Bolt fitment !
« Reply #1 on: 30 March 2014, 16:05 »
Is that a standard wheel bolt? It looks like a ball seat, for an aftermarket wheel you'll need tapered seat.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Bolt fitment !
« Reply #2 on: 30 March 2014, 16:06 »
looks like you need tapered in the new wheels
Offline joshstanvw
Re: Bolt fitment !
« Reply #3 on: 30 March 2014, 17:15 »
For what it's worth I ran the same wheels with those bolts(not by choice bought it like it) for around 3 months+ however long they were on before and never a problem
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
  • Mk4 1.8t AUM
Re: Bolt fitment !
« Reply #4 on: 30 March 2014, 18:31 »
yeh as far as i know theyr standard wheel bolts, looks like ill need a tapered set cheers
Offline northeast_gti-t
  • "1.8T AGU"
Re: Bolt fitment !
« Reply #5 on: 30 March 2014, 20:03 »
you will find standard bolts are radius fitment and as wes has said you need a taper seat fitment bolt as all aftermarket/reps use this bolt fitting.
2000 Mkiv GTi 1.8T AGU
Re: Bolt fitment !
« Reply #6 on: 30 March 2014, 21:31 »
Wrong bolts, you need taper fit, ebay is your best bet
  • Mk4 1.8t AUM
Re: Bolt fitment !
« Reply #7 on: 31 March 2014, 00:01 »
do they need to be 28mm thread as well
  • "1.8T AGU"
Re: Bolt fitment !
« Reply #8 on: 31 March 2014, 01:42 »
they will indeed,the threads on vw taper seat fitment bolts will also be the same too.
