Author Topic: Vacuum hose  (Read 1107 times)
Offline DAMOjarra
  • GTweyI
Vacuum hose
« on: 30 March 2014, 14:37 »
Areet
I recently fitted a fmic to my mk4 gti. When removing the old hot side piping there was a black rubber hose connected to the top of the alloy pipe.
I dunno what to do with the hose, can I blank it or does it need connected to my new hot side alloy pipe?
Here's a picture of the hose in question
Thanks
Offline rockmonkey69
Re: Vacuum hose
« Reply #1 on: 30 March 2014, 14:43 »
That should not be blocked, it should be connected back to your charge pipe
Offline davidgtrr34
Re: Vacuum hose
« Reply #2 on: 30 March 2014, 16:09 »
That pipe is for the boost controller (n75 valve) if you block it or dont connect you will have serious boost problems
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline DAMOjarra
  • GTweyI
Re: Vacuum hose
« Reply #3 on: 30 March 2014, 17:14 »
Thanks guys
