Author Topic: brake light problem  (Read 2056 times)
Offline paynie26
brake light problem
« on: 19 October 2003, 20:04 »
i have a problem with the rear brake light coming on all the time it seems to be the brake pedle. I think i need to adjust the pedal somehow so it touched the switch???????????? >:(
golfvr6
Re:brake light problem
« Reply #1 on: 19 October 2003, 20:06 »
May just be a faulty switch, check the wiring looms to the brake lights too.
Offline essex_lad
« Reply #2 on: 05 November 2003, 11:33 »
Are you sure there's a switch on the pedal ?
My GTI has two pressure switches on the M/C, if either switch goes short circuit due to pressure in the brake fluid then it turns the brake lights on.
