Author Topic: Problem with 2000 1.8t AGU  (Read 2060 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Problem with 2000 1.8t AGU
« Reply #10 on: 30 March 2014, 14:07 »
air leak, I'm going for the S shaped one under the inlet manifold that connects to the PCV
Offline MoMartin
« Reply #11 on: 30 March 2014, 17:55 »
All plugs surrounding the throttle body are plugged in, throttle body has been cleaned, I unplugged the maf sensor to try that, but it just ran really rough, and stalled unless I kept my foot on the throttle.
I'm booked in for a vag com diagnostics test on Tuesday, so I'll see if any error codes appear then.
Thanks, Mo
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #12 on: 30 March 2014, 20:04 »
+1 with this too  :wink:
2000 Mkiv GTi 1.8T AGU
Offline MoMartin
« Reply #13 on: 02 April 2014, 17:53 »
An update on the problem -
Cleaned the throttle body
Found out that the guy who i bought my car off fitted the dump valve wrong ( huge vacuum leak, so that wouldnt help!)
(both didnt sort the problem, but they both helped the problem)
Also got my VAG COM today, cleaned all fault codes, and now it is running fine!
I haven't taken it out for a long drive yet, but by the looks of things, it should be fixed.
Thanks for the support
