Author Topic: Changing Temprature coolant sender HELP  (Read 2094 times)
Offline lukeC
« on: 28 March 2014, 17:58 »
Hi all,
i am having a major blond moment.... Earlier this afternoon i changed rear discs pads and wheel bearings. I also attempted to change the "Blue Temprature coolant sensor" how ever i cant seem to locate it lmao! i have a threaded type sensor from the right of the cylinder head, and another threaded sender from the radiator (i think this is the thermostat sensor?)
The car in question is a 1987 golf Mk2 Gti 8v PB engine code.
cheers
Luke.
Offline Santiago
Re: Changing Temprature coolant sender HELP
« Reply #1 on: 28 March 2014, 18:15 »
Look on the coolant flange that the radiator top hose connects to, between cylinders 3 and 4.
The thing on the nearside end of the head is an oil pressure switch. The thing on the radiator is the thermoswitch that triggers the rad fan.
Offline gazareth
« Reply #2 on: 28 March 2014, 19:34 »
there is a chance your temp sensor is the older style. is the flange on the front of the head black plastic or alloy?
Offline lukeC
« Reply #3 on: 28 March 2014, 20:34 »
i Will update in the morning i should of checked this before buying the genuine part from VW .... like a tit :whistle:
Offline gazareth
« Reply #4 on: 28 March 2014, 22:04 »
well my 87 gti has the alloy coolant flange and the screw in sensor so its probably same on yours.
Offline Brighouse-gti
« Reply #5 on: 28 March 2014, 22:31 »
You've probably got the olde alloy flange that comes out of the cylinder head which doesn't have the blue temp sensor on it. You can do a direct swap for the plastic version of the flange and just plug and play. You will however have to buy the black sensor that sits just in front of the blue temp sensor to fit the flange as your old sensor won't fit. Also the black sensor has two pins, and you'll only have one wire to connect to it, simply connect another length of wire to the other pin and earth it to the right hand side of the intake manifold. Magic! I did this to my pride and joy and it did appear to run better with the blue temp sensor rather than the old one!
Offline lukeC
« Reply #6 on: 30 March 2014, 09:31 »
Heya all,
Yep i have the coolant flange thing, where the is an old type screw in sensor!! gutted! i will be sending the blue temp sender back @ £28.99 and i need to get the other type, can anyone tell me or link me to a decent quality one?
thank you all for your help.
