Author Topic: engine and traction control lights on  (Read 3577 times)
Offline matty james
« on: 28 March 2014, 11:14 »
hi gents- was driving yesterday -put my foot down and my traction control and engine light came on.i know traction control light is linked to the maf -and it comes on occasionly but goes out when i turn key off and on -had a new orig maf on 12 months ago . both lights stay on now when im driving .got codes read -p0102 mass air flow sensor signal too low . the other code which relates to the engine light coming on is -01314/013 engine control module check dtc memory . both lights coming on at same time mean they gotta be linked -car drives great still apart from dash lights and fault codes. know what all possibilities of individual codes -but thers got to be a link between them -anybody got any ideas ?  thankyou in advance
« Last Edit: 28 March 2014, 13:59 by matty james »
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline matty james
Re: engine and traction control lights on
« Reply #1 on: 28 March 2014, 13:53 »
been researchin my prob from older posts -and maybe the engine control module fault code and engine dash light are there because of the maf sensor -signal too low fault code .so does signal too low mean theres not enough voltage goin to the maf sensor -maybe broken/damaged wire or coil pack or naff relay/fuse. any ideas anybody ? :whistle:
« Last Edit: 28 March 2014, 14:00 by matty james »
Offline dom
  • Back in a Mk4
« Reply #2 on: 28 March 2014, 19:07 »
My money would be on the MAF, I had the same problem last year.
Offline matty james
« Reply #3 on: 28 March 2014, 19:58 »
did the faulty maf cause your engine management llght and traction light to come on and stay on dom ?
Offline dom
  • Back in a Mk4
« Reply #4 on: 28 March 2014, 20:05 »
Yup, the only disappeared when I fitted a new one and reset the fault codes
Offline matty james
« Reply #5 on: 28 March 2014, 20:17 »
jesus my maf is only 10 month old -original from dealers too - did u get the fault codes ive got dom ?
thing i dont understand is she still drives great ?
« Last Edit: 28 March 2014, 20:20 by matty james »
Offline davidgtrr34
« Reply #6 on: 28 March 2014, 20:33 »
The signal to low means that your maf is sending a very low signal to the ecu. Nothing to do with power to the maf
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline matty james
« Reply #7 on: 28 March 2014, 20:49 »
explain more please thanks :smiley:
Offline matty james
« Reply #8 on: 28 March 2014, 21:18 »
so i could mean a faulty wire from the maf to the ecu or as dom says just a faulty maf sensor ?
Offline davidgtrr34
« Reply #9 on: 29 March 2014, 12:39 »
Dom is right its the maf sensor thats gone bad
