Author Topic: Has my clutch pedal moved???????????????  (Read 3013 times)
Offline Deefadog
  • Mk2 16V (November 89)
Re: Has my clutch pedal moved???????????????
« Reply #10 on: 03 September 2005, 08:32 »
Mines the same :) about half of the press on the clutch does nothing, and it way past the brake pedal!
is it obvious to see where this clip should go?
a pic would be great ;)
Offline GTI EDITION (aka LTD)
« Reply #11 on: 03 September 2005, 11:28 »
If you look up under the pedal box ( lower trim removed ) you should see a smallish hole on the bracket behind the pedal where the plastic stop  locates.
Better still .....has anyone got a picture ????   :undecided:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline Deefadog
« Reply #12 on: 04 September 2005, 19:23 »
Cheers, i can see what you mean :)
