Author Topic: Coolant temp low  (Read 1684 times)
Offline Leach01
Coolant temp low
« on: 28 March 2014, 07:44 »
First thing I'm new on this forum.
My car is: 20v 1.8t mk4 GTI
Right, problem is my car won't get to 90 degrees and then stay there like they should.
I had an eml on so scanned it and it said coolant temp sensor.
So after replacing it still not getting to temp.
So on the way to work today I tailgated a car for a bit and it goes up slightly.
When driving norm it stays around 70 ish.
And if you get it tick over on idle she slowly goes to 90 and the doesn't go further.
So ether thermostat or water pump.
Anyone got any insight on this!
« Last Edit: 28 March 2014, 07:51 by Leach01 »
Offline topher
  • Administrator
  • fully functioning
Re: Coolant temp low
« Reply #1 on: 28 March 2014, 08:35 »
classic symptoms of a faulty thermostat
Offline WadGTI
  • Golf GTI'er
« Reply #2 on: 28 March 2014, 12:30 »
+1. Overcooling
Offline Leach01
« Reply #3 on: 28 March 2014, 13:28 »
Ah, nice to have that confirmed! Not to fix it :)
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 28 March 2014, 17:11 »
Buy from the dealers don't be tempted with cheap GSF or eurocarparts thermostats they're complete junk. While you're in there you might save yourself some potential headaches by getting a new thermostat housing at the same time.. they tend to warp over time and dribble coolant even with some sealant behind them.
Offline dom
  • Back in a Mk4
« Reply #5 on: 28 March 2014, 19:56 »
Just to reiterate what Topher says, I fitted a cheap Thermostat last year and it failed in less than 2 weeks!
Offline Leach01
« Reply #6 on: 29 March 2014, 21:12 »
Ok. Well today after getting one from mill autos. Has fixed the issue! So thanks guys!
