Author Topic: Time advice ?  (Read 3259 times)
Offline james2
  • No scammers please.
Time advice ?
« on: 27 March 2014, 20:15 »
The clocks go forwards saturday night but i can not change my clock so i will leave it. I need to be up at 6 in the morning. I go to bed at 12 oclock and will set it to 7 oclock in the morning meaning i get 7 hours in bed  :undecided: but if i put the clock forwards at 12 to 1 oclock i only get 5 hours in bed.  :undecided: Please i always get it wrong and get up early .  :laugh:
« Last Edit: 27 March 2014, 20:21 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline dom
  • Back in a Mk4
Re: Time advice ?
« Reply #1 on: 27 March 2014, 20:23 »
If your clock changes automatically then just set your alarm for 6am. If you go to bed at 12 then you will get 5 hours in bed when factoring in the hour lost.
Why not just got to bed at 11 instead to compensate for it?
If you can't change your clocks then set an alarm for 5am.
« Last Edit: 27 March 2014, 20:25 by dom »
Offline james2
Re: Time advice ?
« Reply #2 on: 27 March 2014, 20:29 »
but when i set it for 5 in the morning last time i got up 2 hours early. Im thinking or trying to  :laugh: the clocks go forwards a hour so i put my alarm to 7 am instead of 6 because my clock will be a hour behind. ?  :undecided:
Offline dom
  • Back in a Mk4
Re: Time advice ?
« Reply #3 on: 27 March 2014, 20:55 »
What do you use for an alarm? Your phone or a bog standard clock?
Offline gazareth
Re: Time advice ?
« Reply #4 on: 27 March 2014, 21:49 »
whatever way you look at it. you get an extra hour in your pit :grin: or you could just stay up all night?
Offline dom
  • Back in a Mk4
Re: Time advice ?
« Reply #5 on: 27 March 2014, 21:52 »
You do realise the clocks go forwards, meaning you get an hour less in bed.
Offline gazareth
Re: Time advice ?
« Reply #6 on: 27 March 2014, 21:57 »
oops me be wrong :embarrassed:. so head down at 11pm it is then. or stay awake all night :laugh:
Offline Thom89
  • Looking for an "Icebreaker"
Re: Time advice ?
« Reply #7 on: 27 March 2014, 22:51 »
Thom
Offline gazareth
Re: Time advice ?
« Reply #8 on: 27 March 2014, 23:29 »
 :rolleyes:
Offline VR6_Wherry
Re: Time advice ?
« Reply #9 on: 28 March 2014, 11:18 »
yes but the clock will go forward so will be 08:00
Your clock -   12:00,01:00,02:00,03:00,04:00,05:00,06:00,07:00
Actual time - 12:00,02:00,03:00,04:00,05:00,06:00,07:00,08:00
It is all dependant on if your clock compensates for the change... if it does your clock will jump an hour, for example 12:58, 12:59, 02:00 then at 06:00 it will go off and the correct time will be 06:00 - meaning you get 5 hours sleep
This is correct
