Author Topic: b!tch is misfiring.  (Read 4041 times)
Offline sharki786
  • GOT BOOST??
b!tch is misfiring.
« on: 27 March 2014, 14:39 »
My 8v gti is misfiring. It was fine but i have been having starting issues in mornings but does eventually start only in cold. So i took my battery off to clean the earth points under battery. Anyway i turned ignition on for 30 secs then back off then stated car. Now car misfires on low revs. I will check spark plugs and leads. Anything else to check?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline bigberty101
Re: b!tch is misfiring.
« Reply #1 on: 27 March 2014, 15:02 »
first port of call I woul say is check plugs, then leads, then dizzy contact points and arm, the king lead and coil. if issues is still there then go down the lines of checking fuel, I recon its coil or dizzy
Offline bigberty101
« Reply #2 on: 27 March 2014, 15:02 »
scan on vag com?
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 27 March 2014, 16:48 »
Sparkies are just a year old. Took each lead off and the engine did stuggle. Took maf off while started but as soon as i reconnected it the engine cut out.
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 27 March 2014, 16:50 »
Not yet as its raining and laptops battery is poo so need extension. It revs fine after 2k all the way into the redline. It feels like a 1ltr when in low revs and i put my foot down its like missfiring. Sounds like its not running on all cylinders
*****MK4 GTI T*****
Offline GOLF-MK3-GTI
« Reply #5 on: 27 March 2014, 20:33 »
Spray wd40 over coil and dizzy, sounds like moisture.
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 27 March 2014, 21:31 »
It was fine untill i took the battery off to clean the earthing points, now it sounds like a subaru no joke!!
*****MK4 GTI T*****
Offline bigberty101
« Reply #7 on: 28 March 2014, 12:51 »
when you say sparkies are just over a year old, what do you mean? if you mean plugs replace em, I do mine every 10k, moisture is a high bet but weird it only started after the batter was removed
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 28 March 2014, 13:34 »
Nowere near 10k prob 3k if that. Its not driven everyday. Im going to take the spark plugs out today
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #9 on: 28 March 2014, 14:48 »
New update. Just drove back from work and the car pings/pinks even down hill. Its struggling to move but when revs are 2k you cant tell its missfiring
*****MK4 GTI T*****
