Author Topic: bad MPG after cam belt change  (Read 1669 times)
Offline Dizzie
  • Make friends with your fast
« on: 24 March 2014, 12:23 »
The 150PD was overdue a cam belt change so I tackled that over the weekend.
I'd locked out the cam with the proper tool and made sure the crank was bang on the marks.
The drive to work usually reads 49-52mpg. This morning it was 41 :( The drive home is always 52-55mpg so I'll see what that gives me as I did do a fair bit of overtaking this morning and it was a bit colder also.
I'm wondering if the timing has moved from before as you have those 3 13mm's on the cam that can adjust the timing. I was pretty confident they were tightened the same as they were undone.
The power seems to be just as quick as before running a R-tech remap @ 185bhp/320ft/lb
« Last Edit: 24 March 2014, 12:24 by Dizzie »
Mk4 Golf 150PD
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
Re: bad MPG after cam belt change
« Reply #1 on: 24 March 2014, 18:02 »
Would it not be fair to say that wind conditions alone could effect this as it's only 8mpg? Just a thought
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 24 March 2014, 19:39 »
you need vagcom measuring block 004 for engine. the 4th field tells you if you need to adjust the cam sprocket.
Offline Dizzie
« Reply #3 on: 25 March 2014, 16:25 »
yeah I managed 49mpg on the way home compared to my usual 53-56mpg.
I moved the cam a fraction and got 51mpg on the way to work this morning.
Does the lite version of VDS do the measuring do you know? That's all I have
Mk4 Golf 150PD
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 26 March 2014, 17:27 »
Not sure on that one I've never used vcds lite, think you might need the full version.
Offline Bellend
« Reply #5 on: 27 March 2014, 02:02 »
VCDS Lite does support measuring blocks but requires activation for most things.
Where all my moneys went.
