Author Topic: mk2 jetta gt trip computer problems  (Read 1863 times)
Offline jettagreny
« on: 21 March 2014, 22:46 »
hi i have a jetta gt with a trip computer i recently had the engine out of it to clean it up and also fitted a stainless manifold and full system.  before i had the engine out the trip was reading an average mpg of around 30mpg but after i refitted the engine it doesn't get above 12mpg! i hope this is wrong! dose anyone have any ideas as to why it is doing this?
Offline gazareth
Re: mk2 jetta gt trip computer problems
« Reply #1 on: 22 March 2014, 00:24 »
sounds like the small vacuum line from the brake servo pipe to the back of dash clocks is not connected. if the clocks are not getting a vac reading of the engine they think the car is running flat out all the time.
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 25 March 2014, 20:33 »
Gaz how does the mk3 get it mpg reading?
Offline itavaltalainen
« Reply #3 on: 25 March 2014, 23:16 »
from ecu
Offline gazareth
« Reply #4 on: 26 March 2014, 00:48 »
glad someone stepped in there coz I have no idea :grin:. but I would think the ecu takes readings from engine speed/throttle position and air intake.
