Author Topic: AGU couldn't be mapped?  (Read 3835 times)
Offline leigh_harty
  • Audi AGU
« on: 21 March 2014, 18:08 »
http://www.dynodrive.co.uk/
Went to these guys last Monday as they're close by, my a3 AGU couldn't be remapped because it hasn't got a Bosch ecu? Anybody ever had this problem before or will it be just a case of this company hasn't got the tools etc to remap what ever ecu I have?
Leigh
Dont lose your dinosaur!
Offline Chris.
Re: AGU couldn't be mapped?
« Reply #1 on: 22 March 2014, 19:32 »
Doesnt have a bosch ECU.....fairly sure ALL mk4s came with a bosch ECU.
They probably dont know what they are doing.  Get along to somewhere such as R-tech and they will give you a top quality map.
Click For Build Thread
Offline shaft69
« Reply #2 on: 25 March 2014, 20:25 »
Chip has to come out of ecu and load map to it then resoldered in, think that what r-tech done to mine years ago. dynodrive are expensive i map bmw and mini and there maps are £100 more than ours and less hp and tq. R-tech will come up to you and do car done mine in warrington at my work.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Chris.
« Reply #3 on: 25 March 2014, 23:16 »
Never heard of chip coming out on the AGU.  What ecu number is this on?
Probably easier to just buy a 018 CG ecu and put that in.  Easy to code to immo with vcds too
Offline leigh_harty
  • Audi AGU
« Reply #4 on: 27 March 2014, 12:27 »
I had a day off and thought I'd get my car mapped.. instead spent the money saved on brakes and green stuff items  :smiley:
If I got rtech to remap my car I'd rather do things propers and get rid of the dinky ko3.
Cars a 97 r reg if that makes a spot of difference
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #5 on: 29 March 2014, 11:27 »
R is a fairly early one, any idea on a part number? As Chris said if you have the 018 CG ECU it can be mapped via the ODB port like many of us have had done
