Author Topic: Mk3 stalling issues, but not normal!  (Read 2931 times)
Offline boneybradley
  • Back in a Mk3...
« on: 19 March 2014, 20:02 »
I am looking at buying another Mk3 but this has a running issue, when cold it runs fine and then will stall and fail to restart when up to temp and it fails to spark when it's stalled. It's had new crank sensor, temp sensor, maf, relay 30, cleaned throttle body, vac pipes checked and it shows no fault codes.
I am thinking hall sender myself but the mechanic is thinking a faulty ecu, the only other thing the car does is when checking it on vag-com/snap on reader it shows the temp as 110 degrees (90 on the dash) and doesn't seem to over heat (this is with new temp sensor)
b.t.w it dosen't smell fuely etc
Any ideas anyone??
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Mk3 stalling issues, but not normal!
« Reply #1 on: 19 March 2014, 20:21 »
Id be tempted to try another temp sensor and inspect the plug and wiring before anything else. Where was the replacement from?
  • Back in a Mk3...
« Reply #2 on: 19 March 2014, 20:36 »
We tried 2 sensors (new intermotor one and one from my gti, same issue shows but all is ok on mine). I have asked him to check all the wiring as I know certain issues can be caused by bad wires. It still doesn't explain why it stalls and dies till cool though?
Offline madmanmart
« Reply #3 on: 19 March 2014, 22:45 »
Coil?
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline Shizzle
« Reply #4 on: 20 March 2014, 08:00 »
When i baught my golf the previous owner had said he fitted a brand new crank sensor and it did look new  2 weeks later i had the same problems your having after doing the job my self with another new sensor i have had no problems.
I was adamant it was a coil and nearly believed after being in a lay by for an hour AA change the coil and it started but once warm stalled again so got towed home new crank sensor all sorted  :smiley:
MK3 Golf GTI 2.0 16v 3Door Storm Grey
  • Back in a Mk3...
« Reply #5 on: 20 March 2014, 08:34 »
I will look at coil although it looks recent. I know the crank sensor is new as I supplied it. It's the temp issue with the stalling that's beating me although it may not be linked
Offline GOLF-MK3-GTI
« Reply #6 on: 20 March 2014, 13:14 »
Crank shaft sensor or hall sender i would say.
New crankshaft sensors can fail
  • Back in a Mk3...
« Reply #7 on: 20 March 2014, 13:46 »
Coil is new so that's out. I do wonder about crank sensor but I would expect the car to differ from original fault and show on vag com or the snap on reader
Offline robiwill
« Reply #8 on: 23 March 2014, 18:46 »
try the airflow meter or throttle body had loads of issues like this when I was selling MK3 golfs. never had an ecu problem on a Mk3 but going back a good few yrs now
  • Back in a Mk3...
« Reply #9 on: 23 March 2014, 19:20 »
Will give them a try/check  :smiley:
