Author Topic: Fitting original side skirts.  (Read 1824 times)
Offline Shizzle
« on: 19 March 2014, 10:25 »
As title i have nothing on there at the moment and want  to refit side skirts i have everything i need apart from a lot of time. Is the a certain way to fit the runner part onto the body work i  was thinking rivets as i don't have time for any sort of glue to dry and want them to be on there for good.
The main thing i need to know is the height these should be fitted so that the top part with end pieces sits under door without being to high or low.
Is there any guide on this anywhere any help appreciated.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline Len
Re: Fitting original side skirts.
« Reply #1 on: 19 March 2014, 11:48 »
Think the end pieces (rear) have screw on points so that will give you the height and positions.
www.sas.org.uk
www.the-ace.org.uk
Offline Shizzle
« Reply #2 on: 19 March 2014, 12:02 »
OH yes i remember i will have a proper look later and see what i can do on my old golf they were not fitted well and door would hit plastic bit in the end smashed it to pieces looked awful.
« Reply #3 on: 20 March 2014, 13:28 »
They runner part fits with double sided tape and it lines up with a moulding line on the sill they then screw underneath.
Easy enough to refit them.
Offline Foreveryoungaus16v
« Reply #4 on: 20 March 2014, 15:45 »
Keep them off look far better if thereis no rust
163 BHP (TSR POWER RUN)
Offline Shizzle
« Reply #5 on: 20 March 2014, 15:54 »
well i am repairing all the rust i like side skirts and some donut jackedthe car up on the sills so there not pretty and i have some mint side skirts with all the end caps shame to waste them  :rolleyes:
