Author Topic: Speedo Accuracy  (Read 4857 times)
Offline matt2
Speedo Accuracy
« on: 17 March 2014, 17:01 »
As far as I know, all car speedos over-read your actual speed but my GTD is far closer to the real speed (as tested by independent GPS) than any other car that I have owned.
In my Mk 6, the over-read varied depending on the speed that you were doing but at 74 indicated, you were really doing 70.
On the Mk 7, it seems to be a constant 2 mph over-read, regardless of the speed that you are doing.
Has anybody else tested their car to see what it does?
Golf GTD Mk VII | DBP | DSG | Discover Nav
Offline AlanH
Re: Speedo Accuracy
« Reply #1 on: 17 March 2014, 17:17 »
Comparing my speedo against my TomTom, the speedo seems to over-read by 3mph at all speeds.
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline mk7gti
Re: Speedo Accuracy
« Reply #2 on: 17 March 2014, 17:17 »
There used to be a way on the Scirocco to bring up true speed on the AC unit display. I wonder if the Golf can do the same trick...
MK7 GTI - Deep Pearl Black - Standard Spec - Ordered 10/12/2015.
MK7 GTI - White - Standard Spec - Service Pack - Collected 11/09/2013.
Offline ffrank
Re: Speedo Accuracy
« Reply #3 on: 17 March 2014, 17:38 »
This seems to tally with the more accurate MPG readings, if assuming MPG and speedo are using the same data for miles.
Offline dippy_x
Re: Speedo Accuracy
« Reply #4 on: 17 March 2014, 18:44 »
If I set cruise at 75mph TomTom usualy hovers between 72-73mph
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
Offline Ginagee
Re: Speedo Accuracy
« Reply #5 on: 18 March 2014, 00:13 »
I've been worrying that my GTi has been underestimating speed. We've got a few of those warning speed detectors round our way, and keeps flashing at me to slow down when I am at or under the speed limit. I've decided that these things are just not calibrated correctly. :wink:
2014 GTi Mk7 5dr Manual, Reflex Silver, PP, DNS, Dynaudio, Pano Roof.
Offline Skinnee D
Re: Speedo Accuracy
« Reply #6 on: 20 March 2014, 07:58 »
That's the same for my speedo.
I also checked the odometer and that was virtually dead on (actually under-registered by a fraction of a percent over 10 miles).  Having established that I checked the fuel computer a few times with the same filling technique and that was consistently just over 1mpg optimistic.
All in all pretty good really.
GTD + 3 pedals :-)
