Author Topic: Head gasket change  (Read 4575 times)
Offline dan_thevdub_man
Head gasket change
« on: 16 March 2014, 19:12 »
Right guys. Here's the biggy. Took car for service today went in fine came out with a dodgy coolant temp light flashing. Got home to nice the dreaded gunk in the expansion tank and oil cap . So iv decided to do the headgasket myself with a mate. We both pretty handy so why not. Read up that I'll need change all the seals and gaskets and the head bolts and whilst I'm at it though  id do the radiator and expansion tank just to make sure all the junk is cleaned out clean all pipes and breathers. Going do the water pump aswell. Is there anything else. Any help is welcomed but please don't tell me not to bother or to just scrap the car as that is not an option. For the record it's a mk3 2.0 8v anni agg 106k miles
Offline itavaltalainen
Re: Head gasket change
« Reply #1 on: 16 March 2014, 21:38 »
Head gasket change I would also change valve stem seals since you need to take head off anyway. Not much more work but a lot easier with head off.
I would do:
new head gasket incl. new bolts (old plastically deform when tightened up to correct torque)
stem seals
rocker cover gasket
cam belt (+ fan belts if they have done some mileage already)
water pump (you could clean it thou)
thermostat
obviously new oil and coolant
however I would first check the oil/water heat exchanger.... if that fails you get same symptoms... curing that is a 2 hour job (including flushing cooling system)... rather than whole weekend for the above...
« Reply #2 on: 16 March 2014, 22:37 »
Where is this exchange/oil cooler that you mention? Iv never heard of it
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 16 March 2014, 23:50 »
I believe that's the oil cooler (part 18 on this diagram)
I know the seals can fail on this but that normally gives you a drip, and they are not connected to the water in any way.  itavaltalainen your needed to explain a bit more  :smiley:
Offline Len
« Reply #4 on: 17 March 2014, 12:27 »
Right pig of a job on a 16v with aircon! No access! :angry:
But on an 8v it should be easy!
Agree with BB in that I dont see how the oil and water would get together in the oil cooler.
www.sas.org.uk
www.the-ace.org.uk
  • Back in a Mk3...
« Reply #5 on: 17 March 2014, 13:06 »
It's not a bad job on the 8v with air con (Unless you sell the seal to a customer before you get chance to fit it  :grin:)
Mine dripped oil from the seal so i didn't need to remove the whole oil filter housing to change
Offline bigberty101
« Reply #6 on: 17 March 2014, 15:00 »
ive heard of a few hailing here, the actual water jacket gets a hold in and allows oil to seem in and visa versa, as said it may not cure the issue but by far its the cheapest and easiest way to go through first.
« Reply #7 on: 17 March 2014, 18:00 »
they can corrode over time and since you have water and oil in there it can actually mix. doesn't happen very often but before I go to headgasket would check that...
you can take it off... connect one of the water ports to garden hose... flush it vigorously with water, then block the second one with a bit of garden hose (blocked with a cork). now fully open the tap and see if there is oil/water coming out on either side of where it screws to block and oil filter.
« Last Edit: 17 March 2014, 20:38 by itavaltalainen »
« Reply #8 on: 17 March 2014, 20:09 »
 :huh:  :shocked: all your vast VW experience and you are not aware that it is an oil / water exchanger.
I have seen many fail, over time they corrode and will lead to oil and water mixing, easy enough to check, join the pipes together and then flush through, if it comes back then your looking at head gasket.
Offline Len
« Reply #9 on: 17 March 2014, 20:49 »
Many?
How come you have never mentioned it then Wayne?
www.sas.org.uk
www.the-ace.org.uk
