Author Topic: Golf 7 GRA Tempomaat programming how  (Read 6454 times)
Offline cebbes30
« on: 14 March 2014, 14:13 »
Hello,
I have build in my car a tempomat/GRA cruise control MFL.
I have buy a steering wheel with GRA option Part No SW: 5G0 959 442 J and by kufatec a cable to connect the steering controller to engine controller, everthing conected with VW diagram.
And today a have go to the VW garage to recode, but the cant recode it because its gives a error the said to me.
I have try by myself with vcds and i get a engine fehler, but i managed to enable cruise control speed limit, i can do this with the MFL.
Address 01: Engine (J623-CJZB)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 E    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 4972
   Revision: WAH08---
   Coding: 01110032232415082000
   Shop #: WSC 00028 028 00070
   ASAM Dataset: EV_ECM12TFS01104E906016E 001006
   ROD: EV_ECM12TFS01104E906016H.rod
   VCID: 24470A1B2F2E243ED0B-8071
1 Fault Found:
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [038] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 13897 km
                    Date: 2014.03.14
                    Time: 11:29:22
How can i upload pictures to here!
Offline p3asa
Re: Golf 7 GRA Tempomaat programming how
« Reply #1 on: 14 March 2014, 15:23 »
Upload your picture to photobucket or similar
then post the link on here.
Incidentally what is tempomaat? I tried googling but apart from speed I'm not sure what it means.
Offline monsta
« Reply #2 on: 14 March 2014, 15:36 »
Cruise control = "Tempomat"
Offline cebbes30
« Reply #3 on: 14 March 2014, 16:26 »
http://i489.photobucket.com/albums/rr253/Hella_444/20140314_122149.jpg
http://i489.photobucket.com/albums/rr253/Hella_444/20140314_122129.jpg
http://i489.photobucket.com/albums/rr253/Hella_444/20140314_122126.jpg
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 1510120003004H
   Coding: 0400
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
   Component: GW MQB Mid    121 1109
   Revision: --------    Serial number: 0000104516
   Coding: 030100042B086400EF000648080F00010001000000000000000000000000
   Shop #: WSC 00028 028 00024
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_VW37.rod
   VCID: 3365F9479AC0B386591-8066
   Generator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
   Component: E221__MFL-DC1  H12 0034
   Serial number: 23120002279540090291
   Coding: 280000
Offline p3asa
« Reply #4 on: 14 March 2014, 17:50 »
Highlight the link and then click the icon "Insert Image" above
Offline monsta
« Reply #5 on: 14 March 2014, 19:28 »
Just a stab in the dark here but do cars in Holland have the radar system?
Perhaps you need to code differently for normal cruise instead of adaptive?
Offline cebbes30
« Reply #6 on: 15 March 2014, 09:22 »
Some of them have radar system but this one not.
You can see i can activate but the give a error on the picture of MFA the give behind the timer clock this tekst ( ! )
I cant change the speed limit from the Engine controller from 210 km to NO limit the engine wont accept this.
Someone els have a same engine but have no speed limit byte 6 bit 4!
Adresse 01: Motorelektronik (J623-CJZB)       Labeldatei: 04E-907-309-V1.clb
   Teilenummer SW: 04E 906 016 E    HW: 04E 907 309 A
   Bauteil: 1.2l R4 TSI   H08 5542
   Revision: WAH08---
   Codierung: 01110032232405082000
Olso he have a updated engine ECU H08 5542 my engine ECU have H08 4972!!
Can this be the problem!
« Last Edit: 15 March 2014, 09:50 by cebbes30 »
