Author Topic: high temp paint for brake hubs/discs what did you use  (Read 2928 times)
Offline Snoopy
  • Moderator
  • Geoff.
Wheel hub/Disc brake hub paint what did you use?
Any links?
Need to paint mine.
Also brake caliper paint anyone know a good match to the red?
I want to paint the bits VW missed..
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline cosmicremedy
Re: high temp paint for brake hubs/discs what did you use
« Reply #1 on: 12 March 2014, 11:47 »
I've used Silver Hammerite in the past, give the Disc centre a quick sand and then paint.  Planning to paint my Calipers in the next couple of weeks using Hammerite (Brush on), although in Gloss Black.  Hammerite always works for me, not sure about the colour match though?
Offline Mattyj
« Reply #2 on: 12 March 2014, 12:10 »
I've heard hammeriate chips jus painted my disc brake splash guards with hammeriate so i'll let you know
Offline Beddie
« Reply #3 on: 12 March 2014, 12:16 »
Hammerite will suffice to a point for a road car, but I learnt the hard way that hammerite + spirited road drive / track = hammerite on fire / burnt paint all over the calipers, wheel inners etc...
I've tried loads of different paints on the hubs and all have failed due to heat at some point or other, best I've found up till now for a silver finish is 'VHT' brand high temp aluminium, for black it's BBQ paint  :smiley:
'Foliatec' red caliper paint is a VERY close match to the VW OE painted red finish, touched mine up a few times  :smiley:
Also, if you're due a disc swap I can recommend the Brembo OE equivalent discs with the UV painted finish on the hubs (dark grey metallic finish), seems very durable, looks great and shouldn't need repainting for a good while if at all...
« Last Edit: 12 March 2014, 12:19 by Beddie »
Carbon Grey ED35
Offline legg360
« Reply #4 on: 12 March 2014, 22:08 »
Ive used this on my hubs, seems to be fine had it on for a few months and still looks good, also had the discs glowing red and it nothing happened to the paid, is rated to 650c.
As mentioned before, I wired brushed, then rough sand then smooth wet and dry, applied this a 1 inch brush 2-3 thin coats.
Halfords High Temperature Engine Enamel Paint
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_175597_langId_-1_categoryId_165495
Golf GTI MK6 5dr Manual - Candy White with Jacara Cloth, Vancouver 18" Alloys, RNS 510, Cruise Control, Carbon Vinyl Wrap Roof, Milltek 3" Race Cat Back.
