Author Topic: Car wont start and loud buzzing from engine bay?  (Read 6471 times)
Offline b_boy02
« on: 11 March 2014, 15:09 »
Hello!
My Mk3 16v has been standing for about 5 months. Today I hooked the battery back up and tried to start it. When I turn the key to turn on the power there is a loud buzzing sound from somewhere around the exhaust manifold in the engine bay. When I turn the key further to start the car...nothing happens. Any ideas??
« Last Edit: 11 March 2014, 16:59 by b_boy02 »
Offline b_boy02
Re: Car wont start but loud buzzing from engine bay?
« Reply #1 on: 11 March 2014, 16:54 »
I think the problems are possibly unrelated.
My immobiliser light will not stop flashing when I plug the three pin fob in...it's a conlog immobiliser, any idea how to reset?
The buzzing is coming from some valve leading off a pipe from the airbox, the valve is under the plastic manifold cover.
Offline jv
  • Administrator
Re: Car wont start and loud buzzing from engine bay?
« Reply #2 on: 11 March 2014, 17:20 »
You sure the battery has enough charge?
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline b_boy02
« Reply #3 on: 11 March 2014, 18:48 »
I think so, I tried with jump leads attached to another car and no difference. The light on my immobiliser socket flashes all the time and I'm pretty sure it didn't before. Any idea if, when the immobiliser is active, you try and start should it turn over and just not start or not turn over at all.
« Last Edit: 11 March 2014, 18:53 by b_boy02 »
Offline spikenipple
« Reply #4 on: 11 March 2014, 19:14 »
The buzzing is the idle stabilisation valve, or ISV for short. Sounds like your immobiliser is stopping the car from turning over.
Offline b_boy02
« Reply #5 on: 11 March 2014, 19:27 »
Ok so can I clean the valve or has it had it?
The immobiliser is a three pin key you push into a slot on the dash. I assume is is not as easy as bridging the wires that lead to the three pins to bypass??
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 11 March 2014, 21:06 »
Im sure my isv used to buzz ,think that's normal,have you got a spare push key to try?
Offline b_boy02
« Reply #7 on: 12 March 2014, 05:51 »
Unfortunately I only have the one push key. I read online that some immobilisers drop the key code after being without the battery for a few days and that hooking the power back up then leaving the ignition on for 15 mins can sort it. Others say to remove the battery then touch the positive and negative leads together.... Anyone know if either of these methods can reset a Conlog immo?
Offline Len
« Reply #8 on: 12 March 2014, 12:55 »
Contact Conlog and see if they have any suggestions.
www.sas.org.uk
www.the-ace.org.uk
Offline jv
  • Administrator
Buy site stuff!
