Author Topic: boost loss?  (Read 4007 times)
Offline Scott D
Re: boost loss?
« Reply #10 on: 08 March 2014, 00:43 »
will need mapping having a stronger actuator/ slightly different turbo as it's probably over boosting with the new turbo on
do you have VDCS or a fault code reader?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: boost loss?
« Reply #11 on: 08 March 2014, 07:51 »
I am not sure if it is stronger actuator than my Forge. I was thinking of putting my Forge with the yellow spring back on because it was remapped at stage 2 with it.
I have the free version of VCDS and a liquid cube, but no faults are showing up, or were you thinking of doing certain logs?
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: boost loss?
« Reply #12 on: 08 March 2014, 09:05 »
If it's anything other than an AGU you can log the requested vs actual boost
Re: boost loss?
« Reply #13 on: 08 March 2014, 09:18 »
can that be done on the free version of VCDS? If not I have a liquid cube and that has something that measures the N75 position. Would that be the same ?
Re: boost loss?
« Reply #14 on: 10 March 2014, 19:52 »
Update!  I had another look for some leaks and underneath the metal plate that is attached to the inlet manifold there was a silicone pipe which is connected to the N112 valve (I think), which I could very easily pull off the valve because the screw on the hose clip had popped out, so I fitted a cable tie and a new hose clip. This definitely made the car much better as I was hitting 17 psi and holding about 15-16  psi, where as before it was only holding at 10-11 psi. I then adjusted the actuator this morning to 3 & 1/2 turns of preload and now the car is holding boost at 18 psi. I  did the usual bhp test of red line in 3rd and I got 243 bhp  :smug:
The car feels so much better and pulls really well  :smiley:
bo
I still think I will go to R-tech and get Niki to tweak the map a bit for the new turbo, supersize tip and ported manifold. I am also thinking of adding some better injectors, and maybe Devils own wmi. As far as I know from what I have read, I can do this without changing the maf because it is an AUM.
What do you guys think?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: boost loss?
« Reply #15 on: 10 March 2014, 22:27 »
You may need the S3 MAF for more power. They're not that expensive and can always be sold on again if not actually needed
Re: boost loss?
« Reply #16 on: 11 March 2014, 07:28 »
ok, thanks. Is the S3 MAF the same size as my AUM one. i.e will it fit in the tip I already use?
Offline Dalo Harkin
Re: boost loss?
« Reply #17 on: 11 March 2014, 12:53 »
bo
Rip it all out and delete the N249 and N112, fit a catch can, one of the best mods I ever did
Re: boost loss?
« Reply #18 on: 11 March 2014, 12:55 »
bo
Have a look at my mod list below my post  :wink:  :smiley:
Re: boost loss?
« Reply #19 on: 11 March 2014, 20:13 »
Spoke with R-Tech this afternoon and all I need to get are some BAM injectors!
