Author Topic: injector replacement  (Read 1436 times)
Offline dmac60
« on: 05 March 2014, 22:51 »
How long would it take for a garage to change the injectors and fuel lines on a v6 4motion roughly? There are no fault lights showing but car isn't running too great and thought I might be aswell changing them.
Offline barrym381
Re: injector replacement
« Reply #1 on: 05 March 2014, 23:35 »
check it checked for fault codes dont just start doing work it does not need  :smiley:
Offline benmanc
« Reply #2 on: 06 March 2014, 08:23 »
If the car isnt runing great just replace every single component on the car without checking what the actual fault is. May as well. Thats the easiest thing to do  :laugh:
Offline dmac60
« Reply #3 on: 06 March 2014, 11:06 »
Cheers, the reason I was wondering about changing the injectors was because I was given carb redEx instead of injector stuff and since then it has unsurprisingly run like crap. I was told by the garage to run through a fresh tank of petrol to flush it out, but I thought I heard the injectors popping when I put the foot down, and the car doesn't seem to be going any better. I just thought changing the injectors might be a bit of a short cut to getting it running well again as I don't do a lot of miles and it would take quite a while for the petrol to work its way through.
Offline WadGTI
  • Golf GTI'er
« Reply #4 on: 06 March 2014, 13:10 »
if you can get it hooked up to vagcom, im sure there is a block for testing the injectors.
Personally, I wouldn't think the fuel lines would be affected. I would stay away from fuel cleaners on these types of VAG motors.
« Reply #5 on: 06 March 2014, 13:35 »
Get it scanned for codes etc as a 1st step and then see what is needed.
Offline dmac60
« Reply #6 on: 06 March 2014, 13:53 »
Thanks guys, I'm working away at the moment so I'll try and get it checked out before I do anything more to it. And I'll definitely steer clear of petrol additives in future!
Offline barrym381
« Reply #7 on: 06 March 2014, 20:51 »
fill the tank with v power an take it for a good drive and give it full throttle  :wink:
