Author Topic: help for new guy with a connection problem.  (Read 3667 times)
Offline GTI EDITION (aka LTD)
Re: help for new guy with a connection problem.
« Reply #10 on: 06 September 2005, 01:12 »
I've just checked the wiring diagram . The wiring for the diagnostics plug have a connection on an ' adapter plate ' which is located on a bracket above the relay plate/fuse box .
This is where you should find the two wires that go to the ECU , one is Yellow ( 0.5 wire size )  the other is Grey with a white tracer ( also 0.5 wire size ) .
The positive feed comes from fuse 21 ( 15 Amp ) then the Q/5 connection on the back of the relay plate via ( dash panel wiring loom)  Red with a white tracer ( 1.5 wire size )
The earth  wire is Brown ( 0.5 wire size ) and is connected into the wiring loom for the instruments .
Hope this helps,
                      Oli   :smiley:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
