Author Topic: help for new guy with a connection problem.  (Read 3666 times)
Offline blue_concept
« on: 31 August 2005, 13:43 »
the other day i brough an vag com cable for my mk3 gti so i can sort the rear abs sensor out. i inserted it into the right connection and it didn't work. after hours and hours of fiddling with the cable and laptop. i open the dash up.
when i opened the dash up i found that the cable was not plugged in anywhere and there was no blatant place to plug the cable in
being a newbie to golfs i didn't wanna start messing about with the wiring, anyone know where the cable is supposed to be plugged in? thanks
Judderi
Re: help for new guy with a connection problem.
« Reply #1 on: 02 September 2005, 11:41 »
Im guessing it needs to plug into the ecu. Just a guess  :smiley:
« Reply #2 on: 02 September 2005, 12:22 »
being a total idiot.. where is the ECU?
Judderi
« Reply #3 on: 02 September 2005, 12:24 »
In the scuttle pannel. The bit where the window wiper motor is. Above the engine under a plastic cover.
Offline GTI EDITION (aka LTD)
« Reply #4 on: 02 September 2005, 14:23 »
The connections for the diagnostic socket loom would most likely be under the dash behind or above the relay plate/fuse box , I'll have a look in the wiring diagram to find its location  :smiley:
(All you will find in the plenum chamber/scuttle panel is a large multiplug that goes straight into the ECU)
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
« Reply #5 on: 02 September 2005, 23:29 »
sorry to be a pain. but i got the car accident damged. i dont have a manual or handbooks. where can i get a wiring diagram from? thanks for replying
« Reply #6 on: 02 September 2005, 23:47 »
Sorry wasn't able to have a look at the wiring diagram today will try tomorrow . :wink:
PS what year and engine code is it ? ( as it will help with locating the correct diagram )
« Reply #7 on: 03 September 2005, 16:16 »
its a 1997 blue colour concept. i dont know the engine code. (where can i find that?)
« Reply #8 on: 03 September 2005, 16:31 »
In that case it'll probably be either an AGG or ADY engine code ( If it's an 8V )
« Reply #9 on: 03 September 2005, 23:11 »
yeah its an 8 value. just found out the exhaust is blowing. i though it was quick enough already cannot wait to get the exhaust fixed. sorry back to the point. where do you get the wiring diagram from?
