Author Topic: Ideas for tuning my golf gti  (Read 1271 times)
Offline Kelvmelv
« on: 03 March 2014, 20:42 »
Hello there  :laugh:
I'm new to forums so be gentl  :wink:
I've just bought a mk4 gti 20v
I bought with a remap already done and a k&n panel filter which is producing just under 200bhp, I've read a few posts about tuning them and the agu engine seems robe more tunable? Not sure wat mine is? It's a w reg.
In the next couple weeks I'm going to buy a fmic of eBay 200 quid, and a sportex back box and race tube along with a decat :-/ ? A walbro fuel pump, was wondering if and wat injectors to get and would I need to upgrade turbo? Been looking at k04-001? What sort of bop wud this get me?
If I was to do any of this would I need to remap ecu again?
Offline davidgtrr34
Re: Ideas for tuning my golf gti
« Reply #1 on: 03 March 2014, 20:49 »
all depends on your budget. If you don't want to upgrade the engine internals then get the k04 and 440cc injectors with supporting mods you should get to 300bhp give or take. If you go much higher than 300bhp then the rods will break.
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Kelvmelv
« Reply #2 on: 03 March 2014, 20:57 »
Ok cheers will take a look at it, what supporting mod would you suggest?
Offline davidgtrr34
« Reply #3 on: 03 March 2014, 21:06 »
full turbo back exhaust
frontmount intercooler
walbro 255 fuel pump
4 bar fuel pressure regulator
stage 3 clutch
cold air intake
Offline Kelvmelv
« Reply #4 on: 03 March 2014, 21:12 »
Ok thanks for ur advice :)
Offline GTi_James
« Reply #5 on: 03 March 2014, 21:13 »
Make sure the engines running properly with a Cam belt check and water pump, thermostat temp sender, flywheel, intake, TIP, charge pipe...you get the idea  :wink:
Offline Kelvmelv
« Reply #6 on: 03 March 2014, 21:18 »
Just bought the car, got history with it with proof of new clutch (standard) cambelt, water pump new maf in last 12,000 miles?
 Not sure wat Tip or charge pipe r?
Offline Kelvmelv
« Reply #7 on: 03 March 2014, 21:20 »
Also my airbag light is on for passenger seat, seat seems a tad lose any ideas?
