Author Topic: Mk5 gti  (Read 3193 times)
Offline Benhayes-gti
Mk5 gti
« on: 03 March 2014, 20:17 »
Hi I am new to this site and after some advice !
I'm about to buy a 2005 mk5 gti is there anything I should be aware off ?
Offline Organisys
  • Old and Slow...
Re: Mk5 gti
« Reply #1 on: 03 March 2014, 20:27 »
Rust.
If it's a DSG, then the 40k service intervals for it.
 :smiley:
Re: Mk5 gti
« Reply #2 on: 03 March 2014, 20:29 »
Ok thanks defo no signs of rust as it's a 1 owner 50k miles garaged all life ! Btw it's a Manuel
Offline barrym381
Re: Mk5 gti
« Reply #3 on: 03 March 2014, 20:36 »
check see if the coil packs have been done under recall and i would do the cam follower if its never been done  :smiley:
Offline Organisys
  • Old and Slow...
Re: Mk5 gti
« Reply #4 on: 04 March 2014, 13:52 »
Check the center top edges of the front wheel arches carefully. The good news is if the car has a good history and no accident repairs, then VW may honour the paint warranty.
Offline mk5GTIDSG
Re: Mk5 gti
« Reply #5 on: 04 March 2014, 15:12 »
Query if the Diverter Valve has been updated to the latest revision (G) and the same with the PCV (N i think).
Offline D Squared
Re: Mk5 gti
« Reply #6 on: 12 March 2014, 11:28 »
where are these parts? any pics? need to check mine...cheers
MK3-MK5- Now MK7 GTi
Offline th3_f15t
Re: Mk5 gti
« Reply #7 on: 12 March 2014, 18:36 »
The diverter valve is either near the front of the engine, near the top (on KO4 turbo cars, like the GTI Edition 30) or at the back of the engine, which will involve raising the car and getting between the engine block and the exhaust down pipe to find it. Plemty of how to guides on the net and videos on YouTube.
THe PCV valve is located at the top, front of the engine. You'll need to remove the engine cover to view it. But to test it, have the engine on and at idle, then remove the engine oil cap FOR NO MORE THAN A SECOND. If the engine tries to stall, it's all good. If nothing happens, repeat but hold it off for two seconds, if nothing then you know the PCV valve is gone. Again, loads of how-to guides on the net, quick Google search loads hundreds.
Moving over to Flickr, sorry for the broken picture links!
Offline mk5GTIDSG
Re: Mk5 gti
« Reply #8 on: 12 March 2014, 20:04 »
Thanks th3_f15t.
Also ask if the Cam Follower has been changed...this is not something you can easily check yourself when viewing a car...there are DIY guides on how to replace it though.
