Author Topic: How do I fix this?  (Read 3380 times)
Offline WeekendMechanic
  • Golf MK3 GTD
How do I fix this?
« on: 03 March 2014, 07:55 »
I turn the key and no crank only a long grinding noise untill I let go of the key.
Then when I try it again it starts like nothing is there and continue ok for about two weeks sometimes even a whole month, can anyone give me some insight into what is causing this and how to stop it?
Thanks
Offline spudboy6
  • Just like a golf ......
Re: How do I fix this?
« Reply #1 on: 03 March 2014, 11:02 »
Get the battery health checked sounds like its giving in , the click will be your starter motor not getting enough power to turn over the engine
Then start looking at the starter motor its self
Offline Len
« Reply #2 on: 03 March 2014, 12:40 »
Also check the main earths.
www.sas.org.uk
www.the-ace.org.uk
  • Golf MK3 GTD
« Reply #3 on: 05 March 2014, 08:32 »
My battery is fine its just a little over a year old and its not just one click, its a grinding noise like metal on metal.
Offline Len
« Reply #4 on: 05 March 2014, 12:30 »
New starter motor then!
Dont think you can get the solenoid section separately
www.sas.org.uk
www.the-ace.org.uk
  • Golf MK3 GTD
« Reply #5 on: 05 March 2014, 15:45 »
What about just greasing it up could it be something is getting stuck once in a while?
Offline Len
« Reply #6 on: 05 March 2014, 20:41 »
No. that could make it worse
www.sas.org.uk
www.the-ace.org.uk
Offline Bellend
« Reply #7 on: 05 March 2014, 21:42 »
Sounds like the solenoid isn't pushing it out fully or there are worn teeth.
Where all my moneys went.
  • Golf MK3 GTD
« Reply #8 on: 06 March 2014, 04:56 »
Ok guys Ill do a little bit more reasearch thanks for all your info :smiley:
Offline Khare
  • The bear that khares
« Reply #9 on: 06 March 2014, 21:31 »
This.
