Author Topic: Vibration when accelerating  (Read 3466 times)
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
Re: Vibration when accelerating
« Reply #10 on: 07 March 2014, 08:26 »
100% Engine mounts. Had this in my dads 2.0 gti I put a thread on here about it and was told its the engine mounts.
Changed them and sorted it straight away!
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline Eddy
« Reply #11 on: 07 March 2014, 18:07 »
I will have a look at the engine mounts this weekend, cheers folks :wink:
Golf 1.8t , Custom R-tech 1.5 remap 202bhp , 3" downpipe with decat , Pipercross panel filter , Forge 007 , Silicone TIP, Oil catch can , 18" S8 alloys , De-badged & de-wipered
Offline Eddy
« Reply #12 on: 30 March 2014, 16:19 »
Changed 2 of my engine mounts and its still the same? Gearbox mount is fine so i guess the next step is to change the driveshaft on passenger side, Are all the driveshafts the same of the 1.8t apart from the ones with the 6 speed box?
Offline joshstanvw
« Reply #13 on: 30 March 2014, 17:12 »
I had the same sort of thing and changed the dogbone and that sorted it 20quid for a powerflex one
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
Offline Eddy
« Reply #14 on: 30 March 2014, 17:27 »
Dogmount was fine, Took it off and checked and it was all nice and tight
Offline joshstanvw
« Reply #15 on: 30 March 2014, 21:13 »
And in regard to driveshaft fitment they are definitely not all the same I think there are 2 if the spline bolts are m8 then it's a 90mm inner joint if they are m10 then it's 100mm had issues with this fitting my new gearbox today had to Change the flanges in the diff
Offline Eddy
« Reply #16 on: 04 April 2014, 08:56 »
Got myself another driveshaft which I will be fitting this weekend. Fingers crossed it does the trick?
Offline Eddy
« Reply #17 on: 19 April 2014, 17:03 »
Changed my driveshaft and its still the same?  :sad:
So an update so far i have changed wheel bearings, ball joint , track rod end, engine mounts, driveshaft, i have also had 4 wheel laser tracking and 2 new front tyres ? Its not the alloys as i have 2 sets and its the same on both sets.
It feels like a wheel wobble or as if i have a egg shaped tyre on the n/s front and it is only there when i accelerate and if i dip the clutch it goes?
Any more suggestions as its costing me a small fortune and its still not right  :angry:
