Author Topic: help needed new boost pipes fitted  (Read 1159 times)
Offline wsmith
« on: 28 February 2014, 18:37 »
so today i finally got around to fitting the last pipe of upgrading the boost pipes it was the TB to inter-cooler pipe and i also took the pancake off and changed the little one on there,so i got it all done took my car for a drive up the street than all of a sudden it started misfiring and lost power so i turned it off went into the shop than started it back up and it  sounded the same. i checked all the pipes outside the shop and all was fine started it up and it was back to normal ??? anyone got and ideas what it could ov been cheers
Offline dom
  • Back in a Mk4
Re: help needed new boost pipes fitted
« Reply #1 on: 28 February 2014, 18:53 »
Sounds like you've got a pretty major boost leak
Offline james2
  • No scammers please.
« Reply #2 on: 28 February 2014, 19:47 »
check the boost pipe to pancake pipe. Mine came off after changing the boost pipe.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline wsmith
« Reply #3 on: 28 February 2014, 20:38 »
Cheers ive just been out and scanned the car( :whistle: dont know why i didnt do it before ) its defo a boost leak ,I will check that tomara thanks
