Author Topic: Need help please car drinking oil  (Read 2163 times)
Offline dane
« on: 27 February 2014, 18:15 »
Hey guys need some help my car has been drinking oil badly I.e put it in 2weeks later my oil lights on got and it's got a funny smell and smokes on odd times people said turbo so changed that but it's still drinking oil smoking and smelling please help
Offline dom
  • Back in a Mk4
Re: Need help please car drinking oil
« Reply #1 on: 27 February 2014, 19:37 »
What engine?
Offline barrym381
« Reply #2 on: 27 February 2014, 21:10 »
What engine?
my guess would be a 1.8t  :smiley:
Offline dane
« Reply #3 on: 27 February 2014, 22:01 »
Yes 1.8 aum my friend just said he thinks it could be my vavle steams because they get to hot and piss oil though
Offline mike1990
« Reply #4 on: 27 February 2014, 22:14 »
Does the smoke appear from a cold start up?
Offline dane
« Reply #5 on: 27 February 2014, 22:28 »
No I'll go for a drive then after if I go slow for a few miles then go to speed up it smokes sometimes a little bit sometimes loads but I know when it's going to happen because I get a smell in the car before I speed up :/ I'm lost don't know what it is and love the mk4 to much to bin it
Offline mike1990
« Reply #6 on: 27 February 2014, 22:33 »
Get the coolant system tested for oil in the coolant, might be the head gasket as stated
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
« Reply #7 on: 27 February 2014, 22:46 »
Is the smell strong when sitting stationary? Could be a leak onto a hot component rather than burning oil.
I thought Volkswagens were supposed to be reliable?
Offline dane
« Reply #8 on: 27 February 2014, 23:03 »
No all the things only happen when drive iv been advised to get head done and skimed and exhaust cacle steam things done as my mate that likes vw cars said it could be that
Offline xxChrisxx
« Reply #9 on: 28 February 2014, 07:03 »
Before you do any of that. Get a compression test done, also whilst the sparkplugs are out check the condition for oil fouling. Also generally check for leaks.
Headgasket would put out plooms of white smoke as coolant would be being burned.
Valve stem seals would only burn oil on a cold start, as the oil collects behind the stem when it cools after a run.
Are you down on power? It sounds more like piston rings to me.
« Last Edit: 28 February 2014, 07:07 by xxChrisxx »
