Author Topic: P04011: evaporative control system  (Read 1992 times)
Offline Leejones12
« on: 25 February 2014, 22:49 »
Hi, I have recently bought a mk5 gti and had the engine management light come on. I have had it scanned and came back with fault code P04011 evaporate control system. Any ideas on possible problems and where I should start?
« Last Edit: 26 February 2014, 17:10 by Rhyso »
Offline mcgee9t2
Re: Advice needed
« Reply #1 on: 26 February 2014, 12:36 »
sure its not p0411
Quote
16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Fuel Pump Relay (J17) faulty
Hoses/Pipes to/between Components faulty/clogged
Secondary Air Injection Pump (V101) faulty
Secondary Air Injection Pump Relay (J299) faulty
Secondary Air Injection Solenoid Valve (N112) faulty
Possible Solutions
Check Fuel Pump Relay (J17)
Check Hoses/Pipes to/between Components Check Secondary Air Injection Hoses/Pipes for Carbonization
Check Secondary Air Injection Pump (V101)
Check Secondary Air Injection Pump Relay (J299)
Check Secondary Air Injection Solenoid Valve (N112)
Offline Leejones12
Re: P04011: evaporative control system
« Reply #2 on: 26 February 2014, 17:18 »
Thanks very much will get
