Author Topic: mpg?  (Read 2617 times)
Offline bigdee
mpg?
« on: 24 February 2014, 18:49 »
hi peeps, just a quick one for the non turbos what sort of mpg are you getting ive got a 1.8 gti non turbo and averaging around 20-25 no mods as such am i well below or just a bit off? just wondering what everyones getting
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
Re: mpg?
« Reply #1 on: 24 February 2014, 18:57 »
Thats low, what sort of driving are you doing? My turbo is getting 35mpg or so.
I thought Volkswagens were supposed to be reliable?
Offline mcgee9t2
Re: mpg?
« Reply #2 on: 24 February 2014, 20:18 »
my old n/a used to get 28-32 If I was ragging it.
32-40 on normal driving (lower end of that if town driving higher end if motorway/dual carriage way.
40-45 if driving like miss daisy.
once got 48mpg :afro:
get it scanned. check when its last service was.
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: mpg?
« Reply #3 on: 24 February 2014, 21:50 »
I would say that is bad, as I can get 40mpg out of mine, if driving sensibly and it is a stage 2 remapped 1.8 turbo
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline bigdee
Re: mpg?
« Reply #4 on: 25 February 2014, 18:55 »
im usually driving quite mild but i do like to give it a bit now and again, ive noticed the airbox cover has one of the tabs that fastens it down broken and also its got one of them ecotek valve things fitted last service was apparently about 6-7 months ago ive checked the air filter and it looks clean
Offline bigdee
Re: mpg?
« Reply #5 on: 25 February 2014, 19:00 »
wheres the best place to get them scanned? and what does it consist of? proper vw nooob here
Offline northeast_gti-t
  • "1.8T AGU"
Re: mpg?
« Reply #6 on: 25 February 2014, 19:05 »
I would look for a member local to you on here as the best bet who will scan your car for a few beer tokens don't go to a dealer as there charges for a scan are over the top!
2000 Mkiv GTi 1.8T AGU
Re: mpg?
« Reply #7 on: 25 February 2014, 19:08 »
or just by a cheep scanner yourself because you will more than likely need it LOTS of times in the future!  :wink:  http://www.amazon.co.uk/U281-OBD-2-CAN-BUS-SCANNER-SKODA/dp/B001C9V89A/ref=sr_1_7?ie=UTF8&qid=1393355038&sr=8-7&keywords=vag+com
  • "1.8T AGU"
Re: mpg?
« Reply #8 on: 25 February 2014, 19:23 »
Alternately get a cheapish vag=com lead and download a copy of vcds from the ross tech website the lite version will allow you to at least scan your car for any codes.
Offline bigdee
Re: mpg?
« Reply #9 on: 25 February 2014, 20:44 »
cheers peeps ill have a look  :smiley:
