Author Topic: REBUILD ENGINE (mechanic required)  (Read 2394 times)
Offline wayedy
  • GTI FOR LIFE
« on: 24 February 2014, 00:33 »
Hi, As iv decided to keep my 8v babe she is hitting her 157k its time engine was rebuilt as im keeping her and want to keep her in original condition as possible. maybe respray some parts to make it look fresher.
im looking for just a trust worthy reliable mehcanic around The East Midland or Near to Nottingham, but can travel to them if abit out, might need a gearbox sorting as she pop out of reverse when parked on hill, but not when on flat,
Im Honestly saying its a sick world out their, people not doing the work and just want the money thats why im asking on here...
[/URL]
Offline RichardBaronGolf
Re: REBUILD ENGINE (mechanic required)
« Reply #1 on: 24 February 2014, 09:32 »
I'd recommend BGK tuning in Leeds, shouldn't be too far from you  :smiley:
Offline Foreveryoungaus16v
« Reply #2 on: 24 February 2014, 09:42 »
Stick the original grill back on instead of the de badged if keeping original.  Will look far better :cool:
163 BHP (TSR POWER RUN)
Offline tweed
« Reply #3 on: 24 February 2014, 11:07 »
Ive seen 80k mile engines sell for £50
For a rebuild you're gonna need crank grind, new main shells, big end shells, bore and hone, piston and piston rings. Then new valve seals, clean the valves etc. For a propa job your talking big money.  Do it cheap and you've just wasted your hard earned.
Look for a low mile 8v engine as they can be had for £50.
Offline tweed
« Reply #4 on: 24 February 2014, 11:08 »
Oh just to add you could do a 1.8 20v turbo conversation for the cost of a full rebuild  :wink:
Something to keep in mind
Offline Bellend
« Reply #5 on: 24 February 2014, 12:15 »
A cheap sh!tty rebuild will be worse than a second hand lump.
Where all my moneys went.
Offline hobbiniho
« Reply #6 on: 24 February 2014, 20:31 »
i take it that before you are planning a rebuild that the engine is pretty much f**ked? theresno pint in doing a full rebuild on an engine that is still running good, but as has been sad getting a second hand low mileage engine will a lot cheaper
Offline tweed
« Reply #7 on: 24 February 2014, 21:21 »
Also you might think engine is nakered but if you replace all the sensors for engine running and injectors you find a few lost bhp's
