Author Topic: agu ko3s running lean / gutless  (Read 1208 times)
Offline seagei
« on: 23 February 2014, 20:14 »
hi guys. recently i have put an agu ko3s into a corrado. in say second gear it picks up great to 40mph but 40-60 there is no power at all. normally id put my foot down and 2nd would go to 60mph no problem. Same with other gears say 3rd going from 60-80mph its gutless and so on. i have pulled a spark plug out and its pretty white. i am yet to get a remap to suit the ko3s  would this cause the power problems? i would have just thought the turbo would run on the ko3 map and still pull well in all the gears. not pumping enough fuel? any ideas? if its deffo a map then i can get that sorted. but if it could be something else id like to get it sorted before i get the car mapped.
thanks!
Offline davidgtrr34
Re: agu ko3s running lean / gutless
« Reply #1 on: 23 February 2014, 21:45 »
the stock map should run fine with the ko3s.
when the car looses power does it hold boost or does it drop off.
also is it limp mode or just a slight loss of power
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
