Author Topic: removing and re fitting front door glass?  (Read 1845 times)
Offline t-dub1902
« on: 23 February 2014, 10:31 »
Does anyone know or have a guide on how to do this??
Offline MBChB
Re: removing and re fitting front door glass?
« Reply #1 on: 23 February 2014, 11:46 »
Do you mean the window?
If so it's easy. To take the door card off (4 retaining screws), remove the handle, door latch surround, bellows for the mirror adjuster and the door lock pin. Then all you need is a 10mm socket to take the regulator out (3 bolts and 3 nuts for the complete electric assembly) and 2 bolts to get the glass off the regulator.
All you need is a Philips screwdriver and that 10mm socket and ratchet. Easy.
'89 Golf GTI 16V & '02 Beetle V5 Sport
Offline dubber36
« Reply #2 on: 23 February 2014, 11:49 »
It's no too difficult. Remove the door card and membrane, wind the window about half way down, undo the bolts that hold the glass to the window regulator and lift the glass up and out of the door, tilting it forwards or backwards as necessary.
Refitting is, errrrrr, you know the rest...
Offline clipperjay
« Reply #3 on: 23 February 2014, 13:51 »
Top tip wind glass up then masking tape the bugger to door frame so when you take bolts out the glass doesn't drop suddenly plus its always on the right place for glass guides!  :wink:
