Author Topic: Brakecaliper and wireloom?  (Read 1621 times)
Offline Ducco
« on: 21 February 2014, 14:17 »
Hi all... Norway calling here. I own a Golf 2 GTi 8v 84 mod and im looking for some parts that i find hard to locate im my own country.  I'm looking for the right rear brake caliper, and the wire loom for heated seats, i have fitted black leather seats, is form a golf so it's a original part. Or a wire diagram to make my own loom. Also im looking for the switch to the heating.
Offline Mr Blue
Re: Brakecaliper and wireloom?
« Reply #1 on: 21 February 2014, 22:58 »
Hello and welcome to the forum.
As for the calipers - you can use later mk3 or mk4 calipers. Have a quick search  :smiley:
I have a heated seat loom and genuine switch that I will be taking out a car in a couple of weeks. The loom is quite confusing but the pads run 6v each in series so don't put 12v through them or you might kill them.
edit: Also a relay for each seat and the sensor on the seat bases is also required. This sensor is built into the heat pad.
« Last Edit: 22 February 2014, 19:06 by Mr Blue »
Offline Ducco
« Reply #2 on: 23 February 2014, 22:08 »
Thanx for the reply, i did find a brake caliper from an mkIII, what price and you in mind for the loom and way i need to get heat in the seats?
