Author Topic: A few things I need help with  (Read 1166 times)
Offline Loco-Gti
  • still driving
« on: 20 February 2014, 13:39 »
So guys a bird of background regarding the car it's a w reg 2000 Gti 5 door arz immo2 car. It's came with immo 2 cluster but since then I've had it upgraded by rams when he changed and coded the immo3 full fis into the car. Today I opened the bonnet and the car showed the bonnet was open but it doesn't show if any other doors are open.
I do a few problems with the doors though, the front driver side door doesn't get recognised when the door is open or the back passenger side door. But the other two are fine. What I mean by that is the interior lights will not work with the two doors. But the other two are fine, have the same issue with the boot.
Mind you when the car went into service at vw the front driver side door worked perfectly for a while but then messed up again. The immo 2 clocks did have the door opened light I know this has it worked once in a while when it felt like it and there was also a light for the boot and bonnet.
Could the issue be with the some kind of wires in the not working doors. Any input would be awesome and I would be great flu with any help. By the way I do have vw mfd version g but that's gonna be changed to version d so I can get the sat nav on the fis.
1.8t arz 5 door lc9z working on it slowly slowly. bora vents
Offline mcgee9t2
Re: A few things I need help with
« Reply #1 on: 20 February 2014, 13:41 »
Sounds like knakerd door modules to me.
Offline Loco-Gti
  • still driving
« Reply #2 on: 20 February 2014, 14:48 »
whats the best thing to do then? i got a replacement for the back passenger side door. Its a whole door that's gonna be changed. But the front one just get a hold off a new one?
