Author Topic: Plugs in oil with pics!  (Read 3014 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 18 February 2014, 15:07 »
Thought I would check my plugs as my car does not seem to be pulling like she should.
Engine is a 1.8 Turbo.
Each chamber where the spark plugs live have oil in them. I removed the plugs and gave them a clean. They are called 'Beru' plugs and look very tired so need to get some new ones, which ones shall I go for and why is each chamber full of oil?
Thanks in advance.
Offline dom
  • Back in a Mk4
Re: Plugs in oil with pics!
« Reply #1 on: 18 February 2014, 16:26 »
Inner valve cover gasket leaking?
Offline navmk4gti
« Reply #2 on: 18 February 2014, 16:44 »
I had slight leak like that too on my previous mk4 when the rocker cover gasket was bit fooked.. but was not in every cylinder..only one :undecided:
Offline wegotitugetit
« Reply #3 on: 18 February 2014, 16:47 »
i would of said rocker but look at the sides there is no other signs of it been rocker cover it looks dry all around the cylinder at the top which wouldn't normally be dry if it was rocker  but I'm not familiar with this engine to know how it looks and if there a common problem
Offline dom
  • Back in a Mk4
« Reply #4 on: 18 February 2014, 17:16 »
It's dry around the top because the gasket that will be leaking is half way down the chamber, just after it narrows down to a circle
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #5 on: 18 February 2014, 18:12 »
Thanks guys  :smiley:
Would this effect performance as she is not as fast as I was hoping?  She is standard so 150bhp and has done 152k so I suppose I cant expect her to be super quick but a bit faster than she is!
Also.....What plugs shall I get as there are so many for the 1.8 Turbos.
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 18 February 2014, 18:14 »
There are 2 gaskets under the rocker cover. 1 is the main outer gasket and then you have one in the middle where the sparkies go. Get new ones from tps.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #7 on: 18 February 2014, 19:37 »
Thanks mate.....Will do  :smiley:
When I do a rocker cover gasket do the bolts need to be tightened in a certain order at a certain torque?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 18 February 2014, 20:47 »
Not sure on the bolts but spark plug wise just get yourself some copper NGK8s off ebay, should cost you about £8
Offline Nino
« Reply #9 on: 18 February 2014, 21:16 »
Yes you need to do the bolts in a certain way start from th middle and work out like a star and tighten alittle bit at a time each way. All bolts need to be 10N
Current - MK6 GTi Edition 35 - Candy White - 3 door
