Author Topic: Any Transit experts here ?  (Read 1999 times)
Offline JC
  • Back in the North.
« on: 16 February 2014, 19:28 »
 :whistle:
speak up or if the shame is too bad PM me
 :grin:
Offline Mr Blue
Re: Any Transit experts here ?
« Reply #1 on: 16 February 2014, 20:04 »
No expert but had a few. Whats up?
Offline JC
« Reply #2 on: 16 February 2014, 20:05 »
buyers guide kinda stuff Mr Blue.  :wink:
Offline Mr Blue
« Reply #3 on: 16 February 2014, 20:07 »
What year?
Cam chain tensioners (oil pressure tentioned), fuel pumps, Dual Mass Flywheels and rust. Buy the cleanest you can.
Had a few apart now and very easy to work on. Parts can be expensive
Offline JC
« Reply #4 on: 16 February 2014, 20:13 »
cheers, not sure on year, but 03 - 06 ish if a bargain can be found  :whistle:
Offline barrym381
« Reply #5 on: 16 February 2014, 20:18 »
prob get an 06-07 for about 3k
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #6 on: 16 February 2014, 21:08 »
Transits, unless 3 years old or newer, avoid!
Thom
Offline Mr Blue
« Reply #7 on: 19 February 2014, 18:43 »
The 2.4 duratorq is probably the slowest. Good vans overall but boy do they rust!
On the mechanical side of things..
When you view one - fire it up from cold. It should fire up straight away without issues. If it fires up the 2nd go then most likely the cam chain tensioner needs to be renewed for the newer version. This is a labour intensive job but parts are cheap. Tensioner works on oil pressure.
Glow plugs are a mission to get out if they break at the back of the engine. :embarrassed:
Black smoke out of the exhaust is an easy fix with an EGR blank plate and inlet manifold clean out.
Avoid bump starting these (new models might be ok) but you can jump a tooth on the cam chain.
HTH
Offline JC
« Reply #8 on: 19 February 2014, 19:14 »
Thom
peugeot partner then  :tongue:
Offline vaughn
  • now team wagon, and team grumpy trainee
« Reply #9 on: 19 February 2014, 19:40 »
Agree with thom on that
57 plate black 5dr ed30, 1969 bay window devon camper. thats all for now folks, hopefully picking up a wagon tomoz
