Author Topic: Anyone know about aircon?  (Read 4312 times)
Offline John W
« on: 16 February 2014, 17:32 »
Guys
My Son's 8V GTI has aircon, which has worked perfectly since I bought the car 18 months ago. He's living away now and tells me that it's suddenly stopped working-the light on the switch no longer illuminates and it's not cooling.  :rolleyes:
He's coming home next weekend so I want to try to sort it. Obviously I will check the fuses, but what else can I test to find out what the fault is? Would low gas stop the light illuminating for instance?
All help greatly appreciated! :smiley:
Kind regards
John
1997 VW Golf GTI 8V 5 door
1979 Porsche 924 Lux
1982 Porsche 924 Lux Auto
1986 Porsche 944 Lux
1996 BMW 525iX SE Touring (4x4)
Offline tweed
Re: Anyone know about aircon?
« Reply #1 on: 16 February 2014, 17:54 »
Sounds like a switch.
No, low gas would mean it wouldnt cool. It would still come on.
Offline itavaltalainen
« Reply #2 on: 16 February 2014, 17:58 »
Thought it has pressure switch to prevent it from coming on if it's completely empty? Or was that only mk4+?
Offline John W
« Reply #3 on: 16 February 2014, 18:26 »
Just reluctant to pay for a topup if it's the switch etc....... :wink:
Kind regards
John
« Reply #4 on: 16 February 2014, 22:26 »
Could be a fuse but if in doubt get a specialist to check it, air con is not really diy.
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 16 February 2014, 22:42 »
Mine has no gas and the switch still lights, I would try a new switch and then get a leak test done (I can arrange them free in Yorkshire, We only charge if we refill (if the system is no good then no charge))
b.t.w I also have a fully working switch spare  :wink:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 16 February 2014, 23:14 »
I had this with my 16v when i first bought it. Even though the switch illuminates it shouldn't actually work if the gas pressureis too low. Mine turned out to a hole in the condenser so I replaced that along with all the O-rings and drier before getting it recharged.
Ive recently broke this particular car so all A/C parts are actually available to buy now.
Offline John W
« Reply #7 on: 17 February 2014, 06:45 »
Thanks chaps-so it seems that the initial problem is no power to the switch then. Will check the fuse first and test the wiring to the switch-I don't suppose anyone has a wiring diagram for the aircon system, or even just the switch do they?
Cheers.
Kind regards
John
Offline John W
« Reply #8 on: 20 February 2014, 06:00 »
OK-he's checked the fuses which are all fine. I see that there are a couple(?) of relays too and the switch-any experience of what's likely to be at fault and which to test first?
Seems logical to take the switches out and test for 12V / Earth first. Question-how do I pop the switches out without damage?
Kind regards
John
« Reply #9 on: 20 February 2014, 21:12 »
Has it got gas in it, might be worth getting a specialist to check first.
