Author Topic: exhaust  (Read 1379 times)
Offline davidgtrr34
exhaust
« on: 15 February 2014, 21:46 »
I have a 3" exhaust and its fine with the car at standard height but im going lowering the car about 80-100mm. The problem is that when I lower it the axle will completely crush the exhaust.
I had 2 ideas (1) put the exhaust under the axle. (2)fit a pancake piece in place instead.
Does anyone no if these will work or does anyone have any better idea
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline dom
  • Back in a Mk4
Re: exhaust
« Reply #1 on: 15 February 2014, 22:14 »
I ran mine with the rears as low as they would go with the adjusters in along with a 3" exhaust, it was a tight fit but doable.
Offline davidgtrr34
Re: exhaust
« Reply #2 on: 16 February 2014, 01:19 »
Thanks ill give it a try and see if it works. Also I wont be fitting the adjusters
Offline dom
  • Back in a Mk4
Re: exhaust
« Reply #3 on: 16 February 2014, 09:34 »
I think with the adjusters out it will be too low, mine used to rattle on the rear beam if I had any weight in the back.
Ideally you want to 'squash' (for lack of a better word) the section of the pipe that goes over the rear beam, essentially like a pancake pipe.
Offline davidgtrr34
Re: exhaust
« Reply #4 on: 16 February 2014, 10:15 »
Ya but should I let it get squashed or try fitting a pancake piece.
Would it restrict the flow if it got squashed
