Author Topic: What do you think of this? GTI 180.  (Read 3247 times)
Offline ksab
Offline brewey
Re: What do you think of this? GTI 180.
« Reply #1 on: 12 February 2014, 23:15 »
It look's nice and tidy. The fuel will be negligible as it is the same engine just different map, if anything it would be better on a run as it's 6 speed. The tax I can't comment as mine is pre March 2001.
The benefits of the 180 is you get 312mm brakes. And the inside hasn't got the wood which you will be thankful for.
It won't have Recaro's but a set can be picked up on here easily enough,
At the end of the day you need to decide mate.
2000 1.8T ARZ - OEM+
Offline ksab
« Reply #2 on: 12 February 2014, 23:21 »
Is it just my eyes or does there look to be some damage to the arches in these pics?
Looks like an easy enough fix though, which then begs the question 'why hasn't it been fixed'....
Offline brewey
« Reply #3 on: 12 February 2014, 23:45 »
Yeah the front arch/ wing does look dented. Like you said easy fix and it could be a bargaining point get some knocked off. But it all depends on what the rest is like in the metal.
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 13 February 2014, 06:05 »
Front bumper looks like a darker shade aswel.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline dom
  • Back in a Mk4
« Reply #5 on: 13 February 2014, 10:10 »
Front n/s arch is dented, as is the rear o/s and front bumper has a scuff on the o/s corner as well.
You're talking an 'easy fix' but it could well run into a few hundred £.
« Reply #6 on: 13 February 2014, 10:54 »
Buy a cleaner car and remap it.
Offline WadGTI
  • Golf GTI'er
« Reply #7 on: 13 February 2014, 12:12 »
For £1500 or possibly less plus it has a years ticket, i think its pretty reasonable. Mind its at 180 spec :wink:
Can someone clarify "Electronic Differential Lock" on the spec?
Edit... - EDL is the ESP....sorry thought it was to with something else.
« Last Edit: 13 February 2014, 12:26 by WadGTI »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 13 February 2014, 17:22 »
Electronic differential lock is a new one on me
« Reply #9 on: 13 February 2014, 20:40 »
It is traction control, my Octavia had it.
