Author Topic: silicone turbo boost hose's  (Read 4325 times)
Offline wessexgti
« on: 12 February 2014, 20:47 »
does anyone know of a company who make individual silicone hoses,as i brought a 5 piece set and 4 of them fit and the 5th is in no way the right size/shape for the hose its meant to replace-its the hose which goes to the pancake pipe?
also brought the 7 piece coolant hose set from forge,and could only find 5 that fitted,the other 2 just dont marry up to the hoses that my garage seem to think that they should replace.might ring forge again and see if i can nip up to them (when it stops blowing a gale/pissing down) and they can show me which hoses the 'spare' 2 are meant to replace,as 2 seperate garages/3 mechanics all carnt seem to find where there meant to go.any one else had this problem with forge's sets? its a AGU engine mk4 turbo petrol.
Offline sharki786
  • GOT BOOST??
Re: silicone turbo boost hose's
« Reply #1 on: 12 February 2014, 21:01 »
The sillicone set you got is that for an agu?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Nino
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline mcgee9t2
« Reply #3 on: 12 February 2014, 23:04 »
ash hoses
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 12 February 2014, 23:17 »
agu induction hose should be like
and coolant
I list 1 kit for the agu but other options for different codes
Offline Nino
« Reply #5 on: 13 February 2014, 08:05 »
Brad, do you do the coolent hoses for AUM?
  • Back in a Mk3...
« Reply #6 on: 13 February 2014, 09:59 »
Well I do Venair, SFS and Samco hoses and non have a coolant hose kit for the AUM
Now Forge list a coolant hose kit for the 1.8t which doesn't specify engine code, I will try and get some pictures of the o.e set and compare if these fit ok
Offline dom
  • Back in a Mk4
« Reply #7 on: 13 February 2014, 10:07 »
Do you do crankcase breather hose kits for an AUM?
Offline Nino
« Reply #8 on: 13 February 2014, 10:16 »
Cheers brad i know CM do them but they are £80
  • Back in a Mk3...
« Reply #9 on: 13 February 2014, 10:39 »
I list a breather hose (1 piece) for the aum (o.e part no 06A103221AH) at £40 (I will try and get a picture from my German supplier)
I will also ask if they can get coolant hoses (My German is not good so it may be 24/48hr before they reply!)
