Author Topic: Cylinder 4 Missfire  (Read 4610 times)
Offline Olifran
Cylinder 4 Missfire
« on: 10 February 2014, 19:35 »
Had bluefin remap installed on Saturday. Ran fine til today. On the way home gave it a bit of welly and got epc and engine light. Running like a bag of nails!
VCDS tells me missfire on cylinder 4!
Not happy. Will this be coil pack! I hope so.
I'm assuming it's the remap. Bit of a coincidence.
Any help welcome.
Thanks
Chris.
Now - MK7.5 R in Pure White with DCC.
Gone - 2014 Mk7 GTI DSG Pure White - Discover Nav - Park Assist - Winter Pack.
Offline RocketRossUK
Re: Cylinder 4 Missfire
« Reply #1 on: 10 February 2014, 19:56 »
Yeah, probably just blown a coilpack mate. Often happens after a map. It just highlights  weak or worn parts.
I would recommend the R8 coilpack - same price but they handle a higher voltage and fire better. There is a review and stat somewhere online.
Offline Olifran
« Reply #2 on: 10 February 2014, 20:11 »
Thanks Rocket.
Thought it might be. Just swapping them round now to confirm.
Offline AndyWard
« Reply #3 on: 10 February 2014, 20:21 »
Most likely your coil. I blew one soon after my apr stage 1, put r8 coils in after that. No problems since :-)
10 Plate, Silver DSG,  APR Stage 2, APR TBE, Carbonio Intake 1 + 2, Bilstien B8 + VWR Springs, Eibach Front & Rear Roll Bars Powerflex Bushings, TyrolSport Subframe Deadset Collars, Whiteline Endlinks Front & Rear, Neuspeed TOP and Intercooler Pipe, R8 Coilpacks,
Offline barrym381
« Reply #4 on: 10 February 2014, 20:44 »
Thanks Rocket.
check vw see if they had a recall like the mk4 and mk5  :smiley:
Offline Olifran
« Reply #5 on: 10 February 2014, 20:50 »
yes definately the coil pack. Moved it to cylinder 1 (left side of engine looking from front) and the missfire followed.
Can anyone give me part number of R8 ones so i dont have to trawl boards?  :smiley: :grin:
EDIT - Found the R8 ones at awesome gti for £77 a set. Are these good to use with standard plugs?
« Last Edit: 10 February 2014, 21:33 by Olifran »
Offline mike.
« Reply #6 on: 10 February 2014, 21:46 »
There is talk on some forums saying you should change the plugs to match the R8 coils if using those.
Not sure myself.
The standard VW ones were updated to 06H905115B. (05/2012)
I fitted those and have had no problems, running Bluefin Stage 1 as well.
In fact for some reason the exhausts don't soot up any more.  :laugh:
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Olifran
« Reply #7 on: 10 February 2014, 22:02 »
the ones in mine are the A version (mines 2011) where did you get yours from (dealer)?
« Last Edit: 10 February 2014, 22:17 by Olifran »
Offline mike.
« Reply #8 on: 10 February 2014, 22:22 »
Yea, just got them from the dealer, the GTI ones are more expensive than the R8 ones for some reason.
« Reply #9 on: 10 February 2014, 22:30 »
There is no real reason to swap plugs straight away. Get your new coils and see how they run mate, if you feel a lack of power or any kind of misfire then swap them, easy job if they do end up need swapping.
