Author Topic: Idle problem resolved :-) but need advice.  (Read 1676 times)
Offline Mdwalshy
« on: 10 February 2014, 17:11 »
Well after fitting the new air filter and seeing a slight improvement but not getting rid of the bouncy idle , I have been checking the pipes and found this. As soon as I moved it the engine nearly stalled, my question is, is it ok to cut the pipe back and re-
Thanks
Mike.
Offline mcgee9t2
Re: Idle problem resolved :-) but need advice.
« Reply #1 on: 10 February 2014, 17:35 »
so long as you shortening the pipe isnt going to cause any really tight bends that are going to kink or any strech in the pipe it should be fine
(assuming that its just a push on pipe and that it hasent got any special fittings at the end? or if it has can the fittings be re-attached? cant see the pic very well on my work comp. assuming its a vac hose or simelar to do with turbo pvc system?)
« Last Edit: 10 February 2014, 17:56 by mcgee9t2 »
Offline harlemex
« Reply #2 on: 10 February 2014, 17:44 »
snip and rejoin, it will be fine.  :smiley:
Offline Mdwalshy
« Reply #3 on: 10 February 2014, 19:22 »
Does anyone what this pipe is called ? It's split in a number of places so will have to replace the lot. It's runs from the inlet then under the maf and into a valve and then on into the bulk head.
Offline james2
  • No scammers please.
« Reply #4 on: 10 February 2014, 20:08 »
The vac hose for the brakes, it runs to the brake servo. The car will run sh!t if its broke as its a air leak in the inlet mainifold. How the hell did you brake it  :evil:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline james2
« Reply #5 on: 10 February 2014, 20:16 »
thinking about it, mine joined with a rubber pipe over a length of the hard plastic with jubaley clips each side , by the brake servo. Cut the splits out and find a rubber pipe thats a tight fit over the hard plastic pipe and jubaley clips each side. Or get one from a scrap yard or go to vw with the pipe.  :smug:
Offline Mdwalshy
« Reply #6 on: 10 February 2014, 20:37 »
Yeah I have had a idling problem for about a month, vagcom brought up maf signal to low and coolant temp sensor.
Both were changed and then scanned again but the maf signal to low still came up and still had the idle problem so started checking for an air leak and found this. It's split either side of the little valve so might have to cut the pipe back on both sides and then get some rubber piping to go over the plastic pipe and refit. Hopefully once it's done it will sort the idling problem out :-)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 10 February 2014, 21:29 »
Yep this will probably be the cause of your rough idle. Basically unmetered air is getting in so you'll be running lean. Also your brakes won't be as good as they should be
Offline rfn_hodgson
« Reply #8 on: 10 February 2014, 23:00 »
This happened to me but with some bloke test driving the car. And mine just came apart completely lol easy fix though
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
